Quick Cart checkout link
Thread begun 9/04/2009 2:02 pm by 4egidio363291 | Last modified 9/21/2009 5:08 pm by Dani Chankhour | 12385 views | 27 replies |
4egidio363291
I created a quick cart in the upper portion of my page and the checkout link is not working. The view and clear cart functions seem to be working however when I click on checkout, nothing happens. I have to click on view cart then checkout to proceed. I have attached the page with the quickcart and the display page where the checkout is working.
Thank you for the help.
try adding the following at line 1 to see if a PHP error is occurring:
error_reporting
(E_ALL);
If there are no PHP errors, find the following code just before the doctype tag:
// WA eCart Redirect
if ($buy->redirStr != "")     {
header("Location: ".$buy->redirStr);
and change it to:
echo("redirect = ".$buy->redirStr);
if (
This wont so much fix the problem, but may point me in the right direction for finding the cause.
4egidio363291
Error Message
I added to line 1 and received this error message:
Notice: Undefined index: uname in /homepages/44/d232789399/htdocs/buyorsellvideos/sell/games/NintendoDS/sellnintendodsgames.php on line 397
line 397 is:
<td width="123" valign="top"><span class="style31"><?php echo $_COOKIE['uname']; ?></span></td>
try changing that to:
<td width="123" valign="top"><span class="style31"><?php echo isset($_COOKIE['uname'])?$_COOKIE['uname']:""; ?></span></td>
4egidio363291
Add to Cart error
I did that, now I cannot even use the add to cart button. I get this error when I click add to cart.
%3E
Te code change i suggested would not cause this error, please send a new copy of your page, there must be something else wrong.
4egidio363291
requested page
see attached
you have the forms action set incorrectly. change line 403:
<td width="379" bgcolor="#FFFFFF"><form action="<?php echo $_SERVER["../Xbox360/PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>" method="post" name="buy_1_ATC_<?php echo $row_nintendods["Title"]; ?>" id="buy_1_ATC_<?php echo $row_nintendods["Title"]; ?>">
<td width="379" bgcolor="#FFFFFF"><form action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>" method="post" name="buy_1_ATC_<?php echo $row_nintendods["Title"]; ?>" id="buy_1_ATC_<?php echo $row_nintendods["Title"]; ?>">
4egidio363291
still not working
I am not getting error messages but the link still doesn't work. Should I do what you advised in your first response? (see below)
PHP Code:
and change it to:
PHP Code:
Yes, change the code toL:
this will tell us if the redirect is being set.
