Problem with Upload Image
Thread began 8/30/2016 1:45 am by marzio1348169 | Last modified 8/30/2016 2:14 pm by Ray Borduin | 1307 views | 4 replies |
marzio1348169
I entered, as usual, to a new site an upload process image, but this time does not work The filename is saved correct in the database, but on a server are saved three files with strange names:
Why?
xxx_insert.php
It might be some sort of permissions issue. Files are always uploaded with strange names in php. Our code copies the files to the new folder and then renames them back to their original name. It appears the rename is failing, so my best guess would be permissions.
If you send me FTP access and a url to debug I can investigate it further.
marzio1348169
The write permissions are ok, and with DMXzone Upload everything works correctly
marzio1348169
Just to know the upload image within HTML Editor works fine
The problem is only the procedure File Upload
Please send me FTP access and I'll debug the problem to figure out what is going wrong.
