Secondary recordset values in email result?
Thread begun 8/29/2016 7:31 am by Steve | Last modified 8/29/2016 10:04 am by Ray Borduin | 1330 views | 2 replies |
Steve
What is the best way to generate a value used in the final email, that requires a secondary post process based on user input (select list)?
For instance, there is a page with a form. A select list that has a Value (UserID) that is tied to a UserFirstName. The value is a simple integer. The goal is to get the UserFirstName for use in the email.
<option value="<?php echo($users->getColumnVal("UserID")); ?>"><?php echo($users->getColumnVal("UserFirstName")); ?></option>
I tried using the selected value on the email template page with a simple recordset ; select UserFirstName where id = $_POST['UserID']
Seems the email template is not the place for this.
Is the waue_....php file a good place to do the second recordset to use on the final email template?
Or should I be thinking a more javascript /jquery solution that works like AJAX to have the value needed present/generated as soon as the select list selection is made, then using a hidden input field have the value available via $_POST ?
Thanks you advance for the help.
Steve
One solution / option that is close but not viable is removing the value="" attribute so the option value is used in the $_POST
<select id="selectList">
<option>Bob</option>
<option>Jim</option>
</select>
Results in using Bob or Jim as the $_POST['selectList'] but the problem is the "value" as an integer is needed for an earlier upload on the page...
Steve
Here's a nice Jquery method to get the Select List Text (not Value) to post from an updated hidden field:
<script>
$(document).ready(function() {
$("#select-assign").change(function () {
$("#hidden-assign").val($(this).find('option:selected').text());
alert($(this).find('option:selected').text())
</script>
<select name="select-assign" id="select-assign">
<option value="1">Bob</option>
<option value="2">Jim</option>
</select>
<input name="hidden-assign" type="hidden" id="hidden-assign" value=''>
