Fatal error: Call to undefined function WAValidateRQ()
Thread begun 8/25/2016 7:17 am by Kumel | Last modified 8/29/2016 1:53 pm by Ray Borduin | 4984 views | 16 replies |
Kumel
i have a login page & after sign in there seem to be an error.
login form is in booking.php page & error appear on same page after login.
file attached.
The include file for server validation seems to be missing on the page. If you open and click 'ok' in one of the SecurityAssist Show Region server behaviors it should automatically add it, or you could add it manually to the top of the page like:
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
Kumel
thanks its fixed on the same form i added a hidden textfield ie:
<input type="hidden" name="QID" value="<?php echo $row_BookingDetails['QueryID'] ?>">
I wanted this hidden value to be taken to next page for displaying data linked in that hidden field.
But it doesn't seem to work.
This must be cause form action is :
<form class="" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
So in this case what to i do?
Other redirect i have are:
"successRedirect" => 'confirm.php',
"successRedirect" => "confirm.php?QID=" .($_POST['QID']) ."";
Kumel
nope i can't use QueryID in link. It has to be taken from hidden field so.
You mean it has to be posted directly from the form? In that case you may want to store it as a session variable and then refer to it on the next page that way.
Otherwise you could post the form directly to the confirm page, but then you would have to move any server code that responds to the form submit such as the email to the confirm page as well.
Kumel
well in that case, currently login is can we make user stay in same page after login?
current url is using QueryID ie : booking.php?QueryID=48
So would wanna redirect to same page again after login.
You can remove the redirect from the login so that it would stay on the same page.
Kumel
it is staying in same page but query is lost.
example: while login link was http://localhost/**/booking.php?QueryID=50
but then after login it becomes http://localhost/**/booking.php
theni tried this "successRedirect" => 'booking.php?QueryID='.$row_BookingDetails['QueryID'].'',
redirects to : http://localhost/vaahan/booking.php?QueryID=
i tried this "successRedirect" => 'booking.php?QueryID='.$_GET['QueryID'].'',
redirects to: redirects to : http://localhost/vaahan/booking.php?QueryID=
Remove the form action and it should keep the same url with no redirect.
