Results pages show products even without search
Thread begun 8/24/2016 1:26 pm by tmcbinc99963 | Last modified 8/25/2016 2:14 pm by Ray Borduin | 2216 views | 5 replies |
tmcbinc99963
On both my Prod_results page and news_results page it shows items before a search is performed. The items aren't related to any past search or from any search during the current session. I've cleared browser settings, but can't get them to go away. Not really a problem on the Prod_results page, as it will only be accessed via a search from the home page. But the news can only be searched from the news page itself.
Live view link in PM
The links you provided aren't working for me. I'd have to see the pages themselves to see why they return results before a search is performed.
tmcbinc99963
Two pages attached, plus corrected live view links.
Just update the Default Where clause in the DataAssist Search server behavior to: 0=1
That will force it to return no results by default until a search is performed. You could update it directly on line 15 of news_results.php as well.
tmcbinc99963
That worked. Is there a way to hide the entire Results form until after a search? Right now, 'Results' and 'no results found' appear always, regardless of whether a search is made. Tried moving the form source code and 'show if' statements around, but it throws the 'hidden field' and other syntax off.
You could use an IF statement to check the value of $WADbSearch1->whereClause to see if it is the default value to check if a search has been applied like:
if ($WADbSearch1->whereClause == "0=1") {
Code you want to not show
