reading specific record
Thread begun 8/20/2016 12:08 pm by software.current355386 | Last modified 8/26/2016 2:26 pm by Ray Borduin | 1788 views | 3 replies |
it possible to read a specific record in database and display fields associated with that record
You can access the results from a query as an array with:
$Recordset->Results
So if you want to get a random record from that result set you could just use:
<?php var_dump(array_rand($rsiPupil->Results)); ?>
got it working a treat the problem i have now is if there as been a record deleted from the database say record 4 is missing the result i am now getting a blank result, how do ii check that if exist display otherwise forget
If the record has been deleted then it won't be in the results array. Is the record not being deleted but being cleared of data in the database? I'm not sure the problem you are actually incurring, so I can't advise on how to correct it. Can you give me an example with more details?
