Record Insert before page loads to track page visits
Thread begun 8/20/2016 6:35 am by eric284736 | Last modified 8/29/2016 2:12 pm by Ray Borduin | 5373 views | 8 replies |
eric284736
Hi Ray,
I have this setup to insert a record when the page loads so I can track the number of times a page is visited. There are four recordsets on this page that are pulling information based on the clientid variable.
What happens now is the clientid is inserted into the profileview table but it does it 5 times. The first insert is with the correct clientid but then it inserts a NULL, 96, 32, 16 as additional records.
I have included the page to see my code.
thx
Eric
Are you sure it is this page doing the inserts?
I'm not sure what would cause it, but you could prevent it by updating the trigger on line 48 to:
if ($rsDetail->getColumnVal("clientid")) {
eric284736
Yes this is the page that does the insert to track page views.
I updated line 48 to this:
$InsertQuery = new WA_MySQLi_Query($connBLUR_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "profileview";
$InsertQuery->bindColumn("clientid", "i", "".($rsDetail->getColumnVal("clientid")) ."", "WA_DEFAULT");
$InsertQuery->saveInSession("profileview");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
But now it is adding entries before and after the actual page visited. The attachment shows the actual id inserted for the profile in green. The three entries before and after should not be there. I don't think this is the issue but the field name for the date is "dateview". Is that a reserved word?
thx
Eric
It doesn't seem possible. Are you sure nobody else is visiting the site? The insert gets the value from the recordset and the recordset gets the value from the url. The multiple clientID records could only be inserted if someone visited that url with the associated clientID values.
Whatever the issue is, I'm pretty confident it isn't with the page itself.
Maybe try removing the .js files the page is using to see if they are somehow causing the page refresh.
Another option might be to add a few more fields to the database for debugging. Save the value for <?php echo($_SERVER['REQUEST_URI']); ?>
and the value of <?php echo(__FILE__); ?> and the value of <?php echo(session_id()); ?> during the insert. That would tell you the url of the page when it inserts, the page name doing the insert, and the sesison id of the inserting user.
Maybe that would shed light on it. Something strange is happening, but it is really hard to determine why or how that clientID would change or even could change.
eric284736
What is odd is the extra ids it inserts are the same ones 16, 32 and 96.
Another piece of information, I don't think that is causing the problem is I have a URL rewrite setup as such
RewriteRule ^.+-([0-9]+) detail.php?clientid=$1 [NC,L]
How do I capture the additional field in the database that you suggested?
thx
Eric
Create columns to store the information in that table and then set their values to the values I posted above.
eric284736
Thanks Ray, I think that has fixed it strangely enough :)
One other question:
I want to add 30 days to a date that is submitted on a form. So one would enter their graduation date in the form and submit the page. On the redirect page it will take the submitted date and add 30 days and display certain information if that date is with in the date +30 days.
My date submitted is pulled from the form like this <?php echo((isset($_POST["graduationdate"]))?$_POST["graduationdate"]:"") ?>
I know how to add it and display the date like this <?php echo date('Y-m-d H:i:s', strtotime( "+30 days")); ?>
Not sure how to add that to the form post date. Any ideas?
thx
Eric
eric284736
I am trying this:
if ("".((isset($_POST["graduationdate"]))?date("m/d/Y", strtotime($_POST["graduationdate"])):"") ."" <= "".date('m/d/Y', strtotime( "+30 days")) ."") { // WebAssist Show If
So if the graduation date is equal to or less than today's date +30 days then they would be able to proceed otherwise they cannot proceed. However the above is not working correctly.
eric284736
I got! Thanks anyway! The correct code is:
if ("".((isset($_POST["graduationdate"]))?date("m/d/Y", strtotime($_POST["graduationdate"])):"") ."" >= "".date('m/d/Y', strtotime( "-30 days")) ."") { // WebAssist Show If
