email extensions
Thread begun 8/19/2016 9:21 am by Sweens | Last modified 4/22/2019 11:07 am by Ray Borduin | 5379 views | 11 replies |
Sweens
email extensions
I've seen http://www.webassist.com/forums/posts.php?id=37242
One person has a .menu email address and the site wouldn't allow this. Having carried out the first part on the page above, the address can now be added (I couldn't find any instances of the other code in the entire site - perhaps the extension has been updated since then).
However, when that address is the recipient of an enquiry on the attached page, the email doesn't work - all others do.
Is there a global fix available?
Many thanks
Chris
The issue is either in: /webassist/form_validations/wavt_scripts_php.php or /webassist/email/mailformatting_php.php
If you send me a copy of those two files I can take a look and tell you where the correction needs to be made.
(you probably have to remove lines 218-220 of the mailformatting file)
Sweens
Thanks Ray
Cheers
Chris
remove lines 374-376 from wavt_script_php.php
Sweens
Thanks Ray - that seems to have sorted it!
Will I need to manually add all these new domains, e.g. .technology, .photography etc etc?
Cheers
Chris
No, removing that line stops the check for "known domains" since that list is too large and growing too fast to keep up with these days.
Sweens
Thanks Ray - perfect solution!
Cheers
Chris
Sweens
Hi Ray
This has arisen again, with someone using a .club extension
When they enter the address on a contact form, they get an 'invalid address' error.
The fix you previously mentioned is still in place.
Cheers
Chris
It seems to work in my local test. What email address are you using? I may need FTP access and a URL to debug this live if I can't get it to happen here.
Sweens
pm
