Filtering recordset using LIKE failing
Thread begun 9/04/2009 11:13 am by Les Crowley | Last modified 9/08/2009 2:39 pm by Jason Byrnes | 7969 views | 14 replies |
Les CrowleyBeta Tester
I've worked out how to get a checkbox group saved to the db into a single field.
The values in the field are: Seascapes Elvis ZZ Top
This is my recordset and it's using galselect as the parameter that contains the above values.
$_GET['galselect'] = $row_companyid['gallerycategories'];
$colname_prodcats_retail = "-1";
if (isset($_GET['galselect'])) {
  $colname_prodcats_retail = (get_magic_quotes_gpc()) ? $_GET['galselect'] : addslashes($_GET['galselect']);
mysql_select_db($database_rockncom, $rockncom);
$query_prodcats_retail = sprintf("SELECT DISTINCT Category FROM products WHERE Category LIKE %s ORDER BY Category ASC", GetSQLValueString($colname_prodcats_retail . "%", "text"));
$prodcats_retail = mysql_query($query_prodcats_retail, $rockncom) or die(mysql_error());
$row_prodcats_retail = mysql_fetch_assoc($prodcats_retail);
The problem I'm having is that if there is a single value (such as Seascapes) it will return Seascapes from the recordset - it won't return any results if there are multiple words (such as Seascapes Elvis ZZ Top).
Am I missing something in the way the conditional LIKE works?
Any help is greatly appreciated.
tom92909Beta Tester
Try %s%
SELECT DISTINCT Category FROM products WHERE Category LIKE %s% ORDER BY Category ASC"
That gives me the following error.
Warning: sprintf() [function.sprintf]: Too few arguments in C:\wamp\www\rockinCom\index.php on line 97
Query was empty
This may help to clarify a bit - here's the sql from the dreamweaver recordset view. colname is the parameter and I've added % to the end of it. There's no error but it will only return a result if there is only a single word in the parameter.
FROM products
WHERE Category LIKE colname%
tom92909Beta Tester
hmmm that should have worked...
Sprintf might use different syntax than using a straight SELECT statement.
Below works great in PhpMyAdmin ( I just checked to be sure ).
LIKE CONVERT( _utf8 '%s% USING latin1)
No idea what's causing it to fail. I've also tried it was a comma separating the values and get the exact same results ... no results.
Wondering if it's failing because it's not picking up the individual words and it's trying to match records to the entire value... in this case the value is "Seascapes Elvis ZZ Top" and it returns nothing.
If I only have Seascapes it returns Seascapes.
I would think even with the value of "Seascapes Elvis ZZ Top" it would return any record that has any of those words in it.. unless I'm misunderstanding how LIKE works. Or do I have to add something else to make this work?
try:
SELECT DISTINCT Category FROM products WHERE Category LIKE %s'%' ORDER BY Category ASC"
That returns an error also
Query was empty
CraigRBeta Tester
working example with url parameter
try this, hope it works...
$colname_Recordset1 = "-1";
if (isset($_GET['o'])) {
$colname_Recordset1 = (get_magic_quotes_gpc()) ? $_GET['o'] : addslashes($_GET['o']);
mysql_select_db($database_connection, $connection);
$query_Recordset1 = sprintf("SELECT * FROM tblcategory WHERE `Description` LIKE %s", GetSQLValueString("%" . $colname_Recordset1 . "%", "text"));
$Recordset1 = mysql_query($query_Recordset1, $connection) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
Hi Craig,
Same results. Recordset returns nothing but there is no error. Thanks for trying.
Still wondering if it's failing because it's not picking up the individual words and it's trying to match records to the entire value... in this case the value is "Seascapes Elvis ZZ Top" and because there's nothing in the recordset that matches all three words it returns nothing.
anonymous
Craig,
I recently had a similar issue... the only way I have been able to get it to work when trying to query like you are is to first store that recordset as a variable because you need the percentage sign for the like variable - but since it is part of the variable in the method you are using, it will result in an error.
So the way to stop the error is to rewrite the query like this:
$valuetocheck = $colname_Recordset1;
$query_Recordset1 = sprintf("SELECT * FROM tblcategory WHERE `Description` LIKE '%$valuetocheck%' ";
Cheers,
Brian
