Extension not working in Dreamweaver 2015.3
Thread begun 8/12/2016 10:07 am by bpitcher32 | Last modified 8/17/2016 10:35 am by Ray Borduin | 4733 views | 7 replies |
bpitcher32
Recently upgraded from Dreamweaver 2014 to 2015. Version 2015.3 was installed. When I try to install Webassist extensions I get this message:
"Cannot find required data from database. This extension will not be installed." DataBridge and eCart seem to work correctly but MySql Behaviors are not to be found. I need them to continue working, but have no idea where to find them. Any ideas??
You need to open up the Dreamweaver plugin store and download the free "Database and Server Behaviors" extension first.
You may also need to use the dmxzone extension manager to install because adobe dropped support for their extension manager in the latest versions: http://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
Brad Lawryk
Having the same issue - see attached.
I'm not sure what would cause that. I've never seen that Data Sources window in general. Is that from another extension provider?
Brad Lawryk
I solved that problem. Seems I didn't have my testing server running. However now I can't edit or add any inserts, edits or deletes. The UI just flashes on and off real quick.
That implies the secondary installer didn't run properly. Reinstall the webassist extensions and then restart dreamweaver. The first time you open a page a secondary installer should run. Wait for that to complete and then restart dreamweaver again. If it just flashes that means the secondary installer either didn't run or didn't complete.
Brad Lawryk
Thanks Ray,
That indeed was the problem.
bpitcher32
Ray,
I had previously uninstalled the Adobe Extension Manager to run the DMXZone Extension Manager, which did not install the "Database and Server Behaviors" extension that I downloaded. I then re-installed Adobe Extension Manager and then installed the Database and Server Behaviors" extension. The installation failed as it has in the past - BUT - for some reason I now have bindings and server behaviors working in Dreamweaver. Is a mystery, but I am happy!
