How to override webassist css styles
Thread begun 8/09/2016 11:44 am by tmcbinc99963 | Last modified 1/23/2026 4:27 am by odoo | 3337 views | 8 replies |
tmcbinc99963
I would like to add an underscore between each table row in a search result. When I edit the css style, I get underscores on every table cell in the form. Tried creating a new css rule to override, but can't get it to work. This also happens with other elements, such as multiple buttons or text that needs individual styling.
Also, I've created two different search results pages that use the same linked style sheet. However, the style sheet rules get different results on each page. For example, altering the margins on one page doesn't alter the margins on the other page.
I'm not sure how and where you updated the styles, but you should be able to edit what you need in a shared style sheet. I'd need specific urls and references to what css you updated to comment on why what you did didn't work properly.
tmcbinc99963
Solved most of the style sheet issues except these:
There's an outside border around all the search and results forms, but can't seem to find a style sheet for it.
Trying to add an underscore between search results items in a Prod_results.php page. Adding via the 'body,td,th' rule adds an underscore not only to the search results, but also to other cells as well. Everything I've tried either adds the underscore to all cells on the page or only to certain WA dynamic cells in each row of the table. The WADATableCell rule works fine on 'news_results.php', but adds underscores to every cell on the page on 'Prod_results.php'
Lastly, the style Compact_Default works differently on each of the two pages. Prod_results.php is indented properly, while news_results.php is not.
The border you see is the default border around fieldsets.... you can remove it on forms/fd_compact_default.css line 315 by adding "border:0;" to the fieldset style.
To add just a border on the results table try adding a new css line:
.WADAResultsTable td {
The difference in margin on the two pages is because the first one has css on the page itself:
body, td, th {
color: #000000;
margin-left: 25px;
margin-right: 25px;
padding-bottom: 6px;
padding-top: 6px;
That is adding the left margin that you don't see in the other one on the top.
The second page has css on news_results.php that adds the padding to just the second form:
form.DetailsPage {
margin-left: 20px;
margin-right: 20px;
width: auto;
If you remove the custom css from the second page and add it from the first page it will be consistent.
tmcbinc99963
This post has been deleted.
anonymous
Clipping Pix
Here is the Answer
WebAssist CSS styles are typically applied through classes, so to override them you can create a new class with the same selector and then define new styles for that class in your CSS file. Here's an example:
Let's say that WebAssist has a CSS class .wa-button that defines styles for a button element. To override this style, you can create a new class with the same selector like this:
css
Copy code
.wa-button {
background-color: red;
color: white;
font-size: 18px;
In this example, the background-color, color, and font-size properties are all overridden with new values. You can replace these values with whatever styles you want to apply to the element.
You can also add more specificity to your CSS selector to ensure that your styles take precedence over the WebAssist styles. For example, you could add an ID to the element or add additional class names to the selector.
It's important to note that overriding WebAssist styles may have unintended consequences, so you should test thoroughly after making changes. Additionally, if you're using a third-party theme or framework, overriding styles could break the design or functionality, so it's important to review the documentation and guidelines before making changes.
js7880084
Epson printer in error state
odoo
Odoo Migration Services
