htaccess redirect
Thread begun 8/08/2016 5:58 am by Jamie | Last modified 8/16/2016 2:25 pm by Ray Borduin | 4208 views | 11 replies |
Jamie
htaccess redirect
Hey Ray
Just wondering if you might have any insight as to why, on the .htacces file, this 301 works fine:
Redirect 301 /wp-config.php http://www.fbi.gov/
but this one doesnt:
Redirect 301 /article/avoptics-to-provide-optical-harnesses-for-general-dynamics-land-systemsuk-for-ares-variant-of-the-a /http://www.avoptics.com/article/avoptics-to-provide-optical-harnesses-for-general-dynamics-land-systemsuk-for-ares-variant-of-the-aj/
the rewrite that is being used on the latter is
RewriteRule ^article/(.*)$ news_s.php?perm=$1 [NC,L,QSA,T=application/x-httpd-php]
If you go to the page that is being redirected ( http://goo.gl/mOlsT5 ), it is adding ?perm=avoptics-to-provide-optical-harnesses-for-general-dynamics-land-systemsuk-for-ares-variant-of-the-a to the correct url
Have attached the php page itself
TIA
Jamie
Add [L] to the end of the htaccess redirect. That tells it to not keep processing rules lower down on the file.
Jamie
Have tried putting [L] after a single line of redirects, after all the redirects and also at the end of the htaccess file and with all of them I get a 500 error
Can I see a copy of the .htaccess file?
Jamie
sure, here you go
Move the redirect rule you want to have precedence above the one you don't want running.
Try moving lines 20-25 down below line 94
Jamie
'fraid it hasnt made a difference :(
its still appending ?perm=permalink of the page being redirected in the uri
If you give me FTP access I'll try playing with it a bit, but I don't know why that wouldn't work... maybe create a mod rewrite rule to catch that instance first and then redirect to a new page that then triggers the 301 redirect.
Jamie
thanks Ray thats really kind :) please dont waste too long on it as it isnt hugely important. The odd thing is that none of the redirects, after the first one, dont work.
details in PM and files attached
It looks like it will work if you use a RewriteRule for your 301 redirect instead of using the Redirect 301 syntax.
I've updated the first one. (remember your 301 redirect will be cached so you may need to clear your browser cache or use a different browser to see it work)
