Fourth option not on passing price increase
Thread begun 8/02/2016 8:07 pm by phil107723 | Last modified 8/08/2016 10:50 am by Ray Borduin | 1962 views | 5 replies |
phil107723
I have added a fourth option to my product page. I already had working: size, inlet with price increases and configuration with no price increase. I have added a fourth, a choice between having a normal baffle or a race baffle for an extra cost.
However the baffle option is not being added to the price in the shopping cart. In the shopping cart under options it lists (see attached image) size, config and inlet and then it is supposed to show either normal or Race but instead it is showing a 0 (no increase) or 50 for the price increase for the race option. So in the image $500 is supposed to be $550 for the race baffle option.
I am attaching testecart1_PHP.php, a stripped down test page test.php, newshop_cart.php and a screenshot of problem.
Links to the test page is here http://adrenalinr.com/test.php?productID=611
or the one I'm working on here http://adrenalinr.com/newproductdetail.php?productID=611.
Thanks for your time
Phil
It looks like you manually added those columns instead of using the Dreamweaver interface and that caused a few issues in your cart definition file: testeCart1_PHP.php.
Every time you see:
$itemWAUID, $itemBaffle, $itemBafflePriceInc
it should be:
$itemWAUID, $itemBaffle, $itemBafflePriceInc, $itemWAUID
a simple find and replace would probably fix it.
phil107723
Thanks Ray. I'll give it a go. I did add it manually because my interface doesn't always work.
phil107723
Hi Ray I tried that no change. I have also used the interface to add the baffle columns and the WAUID (I don't remember what this is). I also tried putting $itemBaffle, $itemBafflePriceInc, $itemWAUID through the interface and manually and this made it work but erratically , add one product it didn't work, add another and it did, add another and each product would have that fourth option differently.
Is there something else it could be?
Thanks for your time. Phil
I'm guessing it is something related to the hand editing still. I'd update the eCart object through the Dreamweaver interface and then update the add to cart through the dreamweaver interface. The interface should always work until you start hand editing, which can cause it to become erratic.
phil107723
Yes you were right. I went and started from scratch and tried to did it all through the interface and the problem was sorted when I redid the add to cart. I only tried it manually because my versions of the interface and DW don't always co-operate. The code looks exactly the same but obviously something else was updated that I was unaware of. Anyway thanks for your help Ray, I really appreciate it.
