'requested URL was rejected' validation error
Thread begun 7/25/2016 1:10 pm by tmcbinc99963 | Last modified 7/28/2016 6:35 pm by Ray Borduin | 2240 views | 5 replies |
tmcbinc99963
Created Search/Results/Detail pages to allow Db editing via admin. Then created Security pages to use along with those pages.
The Login page used to redirect to the Search page, but now I get the referenced validation error. Have tried both 'logged in to user_login' and 'login success' but neither work (including resetting the browser).
When it was working, was also unable to get the Search page to redirect to the Results page. Even went back to other Search and Results pages created for the site to see how it was done there, but that didn't work either.
You need to update the SecurityAssist Restrict Access to Page server behavior and update the url and specify the login page as the page to go to when access fails.
tmcbinc99963
Now all it does is redirect back to the login page. This must mean the login is failing, but not sure why. It was working before.
You had your form action set to go directly to the search page on the login page. That page has to submit to itself to log in and then redirects to the search page.
tmcbinc99963
The login is fixed, but now it doesn't go to Search page. Changed the login.php form action to login.php and button formaction to ProdAdmin_search.php
I just tested and it redirected to the search page after login. I'm not sure if I'm doing something different but it works for me. Please provide steps to reproduce if you are still having issues.
