galleries with sub cats
Thread begun 7/25/2016 5:14 am by Jamie | Last modified 8/05/2016 10:13 am by Ray Borduin | 5817 views | 25 replies |
Jamie
Hey Ray
That site we discussed briefly the other day with the main gallery and images that would be selected to go into sub categories - have redone the db and now have the main category table (gallery_category_contents) and the image table (gallery_category) as discussed (see attached)
Initial query at this stage is that this structure (as it stands at the moment) doesnt allow for creating the sub category (eg parent category is 'weddings' and then sub categories within that parent category) creation - was wondering what your thoughts would be to best accommodate that?
Cheers
Jamie
Just add a CategoryParentID column to the table and use 0 for parent categories.
Jamie
Yeah, but what about the naming of the sub cat ?
At the moment, each parent category has 1 galery which is identified as gallery_1, gallery_2 etc. Within each of those I need to further subdivide and the client needs to be able to name the subdivisions.....
You can use the same table structure for sub categories, so they would have a name just like the main categories. Just use the name field.
Jamie
hey Ray
as per caht the other evening, have basically got the main structure sorted.
couple of thing at this point:
1) on the update page (attached) amd struggling to get the dropdown at line 215 to show the selection associated with what is in the db
2) on the results page (attached) am struggling to get the sub cat to at line 335 to show and display under the appropriate parent category
have also attached a a screenshot of the db structure
next step is to get the image management pages to associate with the sub categories...
cheers
Jamie
On the update page select list you have:
<option value="<?php echo($Category->getColumnVal("ProductContentsID")); ?>" <?php if (!(strcmp($row_WADAgallery_contents['ProductContentsID'],$Category->getColumnVal("CategoryID")))) {echo "selected=\"selected\"";} ?> style="padding: 5px 10px 5px 10px;"><?php echo($Category->getColumnVal("ProductName")); ?></option>
the value should match the comparison, so I think it should probably be:
<option value="<?php echo($Category->getColumnVal("CategoryID")); ?>" <?php if (!(strcmp($row_WADAgallery_contents['ProductContentsID'],$Category->getColumnVal("CategoryID")))) {echo "selected=\"selected\"";} ?> style="padding: 5px 10px 5px 10px;"><?php echo($Category->getColumnVal("ProductName")); ?></option>
On the results page you should be moving your subcategory recordset into your category repeated region and filtering it based on the row in the category.
Jamie
thanks
on the results page am not sure how to structure the filter and have tried a variety with no luck:
$SubCategory->setQuery("SELECT * FROM gallery_category_contents WHERE ProductContentsID = ? AND CategoryID <> 0");
$SubCategory->bindParam("i", "".(isset($_GET['CategoryID'])?$_GET['CategoryID']:"") ."", "-1"); //colname
and
$SubCategory->setQuery("SELECT * FROM gallery_category_contents WHERE CategoryID = ? AND CategoryID <> 0");
$SubCategory->bindParam("i", "".(isset($_GET['ProductContentsID'])?$_GET['ProductContentsID']:"") ."", "-1"); //colname
and also
$SubCategory->setQuery("SELECT * FROM gallery_category_contents WHERE CategoryID = ProductContentsID");
$SubCategory->setQuery("SELECT * FROM gallery_category_contents WHERE CategoryID = ?");
$SubCategory->bindParam("i", "".($row_WADAgallery_contents['ProductContentsID ']) ."", "-1"); //colname
Jamie
thanks Ray but that just returns all the parent categories rather than just the sub cats ......http://prntscr.com/byy8u6
What is the name of parent category id column? I'm just trying to guess based on your example.
