Captcha is not validating
Thread begun 7/20/2016 3:33 pm by danielsebas | Last modified 2/02/2017 8:27 am by Ray Borduin | 1768 views | 4 replies |
danielsebas
Hi I put captcha and server validation in a form but is not working.
Give your submit button a name="submit" attribute and I think that will make it work.
danielsebas
Hi Ray, thank you it worked, but the page won't refresh in the same section and the information of all the form is erased.
Use the "validated entries" bindings to set the values of the form elements to the previous values after a failed validation.
danielsebas
Thank you Ray, it worked. I put the redirection to the section id so it will go to the contact section if it fails, something like this:
index.php?validation=false#contact
