Custom Calculation with variable
Thread begun 9/04/2009 8:55 am by cheryl75100 | Last modified 9/04/2009 11:48 am by Jason Byrnes | 1727 views | 1 replies |
cheryl75100
I have a site that has a single set of prices with a conversion code.
Canadian shoppers have a 1.0 conversion
Us shoppers have a variable conversion code
The value of a conversion variable is set during login.
I want all prices to run based on this conversion code.
How do I set that up in the calculations pane of the ecart?
for Session("ConversionValue")
TotalPrice = [Price] x [Quanitity] x ???
Create a New Cart Column, in the Add to Cart server behavior, bind the column to the session variable value so that the conversion value is stored in the cart for each item. You can then use the new cart column in your calculation.
