Datepicker and DB insert 0000-00-00
Thread begun 7/20/2016 7:53 am by tony | Last modified 7/22/2016 9:24 am by Ray Borduin | 3442 views | 5 replies |
tony
Hi all,
strange things are happening here.
The inserted db value related to the datepicker field is always 0000-00-00.
So, I changed the insert db binding value from:
<?php echo ((isset($_POST["data_scontrino_reg"]))?$_POST["data_scontrino_reg"]:""); ?>
to
<?php echo ((isset($_POST["data_scontrino_reg"]))?date('Y-m-d',strtotime($_POST["data_scontrino_reg"])):""); ?>
But now the inserted value is in the wrong format:
yyyy-dd-mm
instead of the required one:
yyyy-mm-dd
AAARHGHHHH!
Please note the datepicker format is specified in the datepicker UI is dd/mm/yyyy.
Can you help me to fix this?
TIA
tony
Change the datepicker format to use: dd-mm-yyyy
php automatically recognizes slash separated as US format with month first, but will treat dash separated dates as day first.
tony
Hi Ray,
Thanks for your reply, it works.
But is there a way to use the format dd/mm/yyyy?
TIA
tony
You could replace slashes with dashes in the binding instead like:
<?php echo ((isset($_POST["data_scontrino_reg"]))?date('Y-m-d',strtotime(str_replace("/","-",$_POST["data_scontrino_reg"]))):""); ?>
tony
Thanks for this reply,
but I can't find a way to make WA server validation works between datepicker and date/time server validation.
Here is my setup:
Datepicker: validation date 03.png
WA date/time validation 1:validation date 01.png
WA date/time validation 2:validation date 02.png
But validation ALWAYS fails, whatever date I insert.
Please note that the insert/bindings are now correct, thanks to your suggestion.
ANy idea?
TIA
tony
Try using US format in the min date field: 7/15/2016
Also do the same replacement in the server variable setting that you did for the insert:
<?php echo ((isset($_POST["data_scontrino_reg"]))?str_replace("/","-",$_POST["data_scontrino_reg"]):""); ?>
