Why I can not add to cart using www.mysite.com instead mysite.com
Thread begun 7/20/2016 7:21 am by Jose | Last modified 7/20/2016 12:25 pm by Ray Borduin | 2591 views | 6 replies |
Jose
Hello, I am trying to use www.mysite.com instead mysite.com through httaccess with rewrite mode but when I try to add item to the shopping cart it not working. I am not using SSL. Do you think that it could be the probrem?
It shouldn't make a difference. Do you have a url where I can see the problem?
Jose
Yes, if you need FTP let me know.
Yes I'll need FTP information to see what htaccess code you used.
Jose
The problem is you have a <base> tag on your page like:
<base href="http://nextperia.com/">
if you want to force www. then you need to have it in your base tag.
Jose
Ok thank you Ray for your help. I appreciate it
