adding options
Thread begun 7/19/2016 8:55 am by Jamie | Last modified 7/19/2016 2:14 pm by Ray Borduin | 3843 views | 12 replies |
Jamie
adding options
Hi Ray
Am trying to get the options on the attached product detail page to be passed to the cart but not able to. Have updated the ecart object and atc (attached) but not figuring out what I am doing wrong. Have also attached the product detail page as well as the cart page
Cheers
Jamie
I'd have to debug where the issue is. Since you are building the options into a string on the top of the page on lines 93-115 my guess is that the error in the logic would be debugged there. It appears you would be adding the options to the cart with the code you have, so I'd guess that the options aren't being built into the AddOption variable correctly to begin with.
I'd start by adding debug code in the IF and two FOR loops like:
if (isset($_POST['ProdOptions'])) {
echo("in IF ");
for ($x=0; $x<sizeof($_POST['ProdOptions']); $x++) {
echo("first FOR ");
for ($y=0; $y<sizeof($_POST['Option_'. $_POST['ProdOptions'][$x]]); $y++) {
die("second FOR ");
That would hopefully identify if the add option code is even running.
Jamie
ok, added the debug code but nothing showing. live page in pm
That tells you it isn't getting into the code at all. Which means that the trigger isn't getting satisfied... Which mean there is no form element named "ProdOptions" being submitted.
I can see that hidden form element exists, but the <form> tag wraps around just the add to cart button and not the <select> and hidden form elements.
I think it may just be a matter of moving the <form> tag so it wraps around all of the form elements.
Jamie
OK, thats showing the debug now (in IF first FOR second FOR ) - I have removed it but the option selected isnt being passed to the cart it just shows : (underneath product name).
attached updated file and link to product in PM to add to cart
Now add debug code to the end (lines 112-114)
die("options: ".$AddOption);
See if it has the correct value before the add to cart code.
Jamie
ok,getting
options: :
OK that means your recordset isn't returning a result. Add more debug information like:
echo($ProductOptionsSelected);
var_dump($SelValue);
Jamie
ok, now its
Resource id #11bool(false) options: :
Looks like you are missing this after line 99:
$selOption = $_POST['Option_'. $_POST['ProdOptions'][$x]][$y];
