Results page returns all results
Thread begun 7/18/2016 2:33 pm by tmcbinc99963 | Last modified 7/20/2016 11:37 am by Ray Borduin | 2515 views | 6 replies |
tmcbinc99963
The results page returns all items from the database no matter what is entered in the search field. Only the product number returns the correct results.
File attached.
I can't access that page.
tmcbinc99963
Why?
It keeps giving a connection error that it can't connect to the database.
tmcbinc99963
Should be ok to view now.
You were searching both text and numeric columns and using a number type search. If you enter text it evaluated to zero and some of your number fields had a zero value.
I broke up your search into text and numeric fields and added logic so that the number columns would only be searched if a number was entered.
tmcbinc99963
Thanks. Works as it should now.
