eCart Checkout page getting 'no such file or directory' warning
Thread begun 7/14/2016 11:17 am by tmcbinc99963 | Last modified 7/15/2016 12:14 pm by Ray Borduin | 1528 views | 5 replies |
tmcbinc99963
Trying to add additional eCart Checkout pages to my existing 'RequestForQuote' eCart Display page. This will be a request for quote, so won't need any shipping or payments, just need a way to confirm the 'request' and add company name/address/etc.
Getting the following error message (it looks like a file needs to be transferred to the live server, but I've recently transferred the whole WA folder over):
Warning: require_once(webassist/ecart/checkout/credentials/gateways.php) [function.require-once]: failed to open stream: No such file or directory in /services/webpages/util/p/j/pjeq5yzb.attwebspace.com/tommcbrideinc.com/public/primrose/confirm.php on line 2
Can only view live, because I'm getter a 'header not sent' error on another page previous to this one when viewed locally.
Upload the file referenced in the error:
tmcbinc99963
In webassist/ecart/checkout I don't have a credentials directory or a file called gateways.php to upload. All I have is a 'js' folder with 'payment options.js' in it.
Also, there appears to be an additional webassist folder inside my original webassist folder, that has many of the same directories. I've added additional WA forms and checkout pages to the site recently. Is it normal for WA to have two folders of the same name, one inside the other?
are you looking in: /primrose/webassist/ecart/checkout/credentials/gateways.php?
That is where it should be. That file should have been created when running the checkout wizard.
tmcbinc99963
That file doesn't exist, nor do I have a credentials directory. Do have the web assist/ecart/checkout though.
Should I start over? Tried opening and closing the wizard again, but no change.
Since you aren't using a payment gateway, you can just remove that line. Delete line 2 of your confirm.php page and it should correct this issue.
