Mysqli update sb not updating page
Thread begun 7/11/2016 8:39 pm by EmmaMorris | Last modified 7/12/2016 3:04 pm by Ray Borduin | 2872 views | 4 replies |
EmmaMorris
I am trying to make the update behavior work after creating a form with Webassist.
First off, I have created a form manually, assigned the fields from a record set, and then applied the update behavior and it works perfectly.
The problem comes when I create a form with Webassist ( so I can use the styling and the validation ). I create a form and bind the fields to the form. It comes up with the current values of the database with the userID I have requested. When I apply the Update Record server behavior, it goes to the index page like it ran but it does not change the database. I have tried binding to both the form and the validated form. Neither works.
Would sure appreciate some input..
I'd need to see a copy of the page in order to determine the cause of the problem.
EmmaMorris
I am sending you the edit.php page. There have been several iterations of this page so this is the current one. All had the same result.
When I go to do the Binding there are 3 forms available in the list. AdminUserLogin_Sharp_default, Current working form, and WA_validated_entries.
I figured I should use the first one, but have tried the others also.. The form does bring up the current values of the db.
By the way, I do not care if there is validation on this edit form. The add form has it and it works fine.
Thanks for the help.
Try just removing the form action. The current action isn't forwarding the ID that you are passing in the url and if you change it to action="" it will automatically forward it. That is probably the issue since it is trying to use the ID from the url to determine the updated record.
EmmaMorris
Once again you come through... I did have to remove the UpdateQuery->bindColumn("userID") line as it deleted the userID completely.. But now all is well. Wanted to make sure I could make it all work on a small form as I am getting ready to do a very large one... Thanks, and have a great day, until next time..
