No Progress Bar
Thread begun 9/04/2009 7:56 am by dcb286193 | Last modified 9/17/2009 1:17 pm by Jason Byrnes | 9630 views | 13 replies |
dcb286193
No Progress Bar
I just purchased FilePro2 for the progress bar. Uninstalled the previous version then installed the new version, removed all the old code from the page and started fresh. When I finished the file uploads OK but no progress bar shows. Any Ideas?
tom92909Beta Tester
I too have experienced similar issues in the past, but this is what I've done to get beyond that recently. I am assuming from your message that you no longer have the v1 extension installed.
1. Delete all occurrances of the WA_DigitalFilePro directories on both your local development system and on your webserver.
2. Close Dreamweaver. Then restart Dreamweaver.
3. Open and edit your upload page again in Dreamweaver. Simply open up the WA Upload Files Server Behavior and click thru the Digital File Pro options (no physical changes necessary).
4. Locate the newly created WA_DigitalFilePro directory on your local machine. This should be available now. This will ensure that you've got a new copy of the v2 file.
5. On your Upload page, Physically highlight only the actual <FORM></FORM> section of your upload page, and then using the Dreamweaver menu, go to Insert, WebAssist, Digital File Pro, Progress Bar. From there you will be able to choose the animation you want to use. Save your file.
6. Check your local WA_DigitalFilePro directory. You should now have the following files.
* HelperPHP.php
* jquery-blockui-formprocessing.js
* <images> directory
7. If all has been verified to be accurate, upload both your upload page and the WA_DigitalFilePro directory to your webserver. You should see the results you expected.
I hope this helps you out! ;)
dcb286193
Progress Bar
Followed your instruction with no success any other ideas?
tom92909Beta Tester
To get a better grasp of your issue and to better assist you, please provide me with your upload page in your next post/reply.
Also verify that you have the actual v2
WA_DigitalFilePro
directory and it's contents on your server.
dcb286193
No Progress Bar
Attached is the page I am working with. I deleted all the WA_DigitalFilePro on the server and reloaded. I went into Extension Manager and verified I am using 2.0.1.
tom92909Beta Tester
I assume that the paths below are all correct on your server?
<?php require_once('Connections/data.php'); ?>
<?php require_once("WA_Universal_Email/Mail_for_Linux_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
<?php require_once('site_includes/session_variables.php') ; ?>
dcb286193
No Progress Bar
Yes the links are up-to-date. The upload does work, just not the progress bar.
If this is the correct path to the Digital File Pro HelperPHP.php file:
Then you will need to change the path to the jquery-blockui-formprocessing.js from:
<script type="text/javascript"> src="../WA_DigitalFilePro/jquery-blockui-formprocessing.js" </script>
<script type="text/javascript"> src="WA_DigitalFilePro/jquery-blockui-formprocessing.js" </script>
dcb286193
Progress Bar
I have change the src as indicated and still no progress bar. I have included the page I am working on for further suggestions. I appreciate the help.
The name of your form is not a legal form name:
<form action="" method="post" enctype="multipart/form-data" name="upload file" target="_self" id="upload file1">
spaces are not allowed in form or element names.
Remove the space from the form name, you will need to delete and re apply the progress bar after renaming the form.
