Insert form: bind db fields to which values?
Thread begun 7/06/2016 2:30 am by tony | Last modified 7/06/2016 9:44 am by Ray Borduin | 1715 views | 3 replies |
tony
Hi all,
I have a custom form on the page and I will insert the data entered in a db record.
In the Insert Record server behaviour I usually bind all vaues to the form entities.
But in the entities windows there are also the WA Validated entries.
So, my question is: have I to bind the db fields to the WA Validated entries?
TIA
tony
Bind them to the form entries. The validated entries are to bind the form elements to their previous values when the validation fails, they won't work for insert or update because they only have values when the validation fails to begin with.
tony
Thanks for your reply.
Just to make it clear (to me): I added the persist data behaviour and bind all form fields to the persist form entrie, so that the user has not to re-enter data when validation fails and the page reloads.
Is this correct?
TIA
tony
That should work.
