Repeating tables - repeat by across columns rather than down rows
Thread begun 7/05/2016 12:31 pm by iain331081 | Last modified 7/12/2016 11:55 am by Ray Borduin | 1871 views | 5 replies |
iain331081
I have a page with a repeating table, but it is repeating like this:
1--4
2
3
Instead of
1--2--3
4
It might be because of the <div>, but I'm not sure how to change it.
Hopefully this is straightforward if you know where to look?
Thanks.
I have attached the page below.
I think your div just needs to be inside your repeated selection so instead of:
<?php if ($totalRows_WADAlodges > 0) { // Show if recordset not empty ?>
    <?php do { ?>
      <div class="large-4 columns home_middle_borderless">
// RepeatSelectionCounter_1384544914955 Begin Loop
$RepeatSelectionCounter_1384544914955_IterationsRemaining = $RepeatSelectionCounter_1384544914955_Iterations;
        while(
$RepeatSelectionCounter_1384544914955_IterationsRemaining--){
        if(
$RepeatSelectionCounterBasedLooping_1384544914955 || $row_WADAlodges){
        <br>
        <br>
        <table width="100%" border="1px">
          <tr>
            <td><img  src="../images/lodges/key_photos/<?php echo $row_WADAlodges['profile_key_photo']; ?>" alt="Key Photo" width="180px" height="144px"/></td>
          </tr>
          <tr>
            <td><h5><?php echo($row_WADAlodges['Lodge']); ?></h5></td>
          </tr>
        </table>
} // RepeatSelectionCounter_1384544914955 Begin Alternate Content
else{
        <?php } // RepeatSelectionCounter_1384544914955 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1384544914955 && $RepeatSelectionCounter_1384544914955_IterationsRemaining != 0){
            if(!
$row_WADAlodges && $RepeatSelectionCounter_1384544914955_Iterations == -1){$RepeatSelectionCounter_1384544914955_IterationsRemaining = 0;}
$row_WADAlodges = mysql_fetch_assoc($WADAlodges);
$RepeatSelectionCounter_1384544914955++;
// RepeatSelectionCounter_1384544914955 End Loop
      </div>
      <?php } while ($row_WADAlodges = mysql_fetch_assoc($WADAlodges)); ?>
    <?php } // Show if recordset empty ?>
you would want something like:
    <?php do { ?>
        while(
        if(
        <br>
        <br>
          <tr>
          </tr>
          <tr>
          </tr>
        </table>
      </div>
else{
            if(!
Really since you are using floated div tags you don't even need to use a repeated section. The repeat region would be enough like:
    <?php do { ?>
        <br>
        <br>
          <tr>
          </tr>
          <tr>
          </tr>
        </table>
      </div>
You only need repeat selection if you are actually repeating <td> tags or doing multiple inserts or updates.
iain331081
Thanks Ray - see what you mean about the repeating <div>s now that you mention it!
iain331081
Hi Ray - I have that all working, but can't seem to get the text to the right of the small images align to the top - I have added a simple class, but its not applying, and can't see it in Firebug at all. Can you see from Firebug why its not seeing it? The rule is applied to the <td>:
<td class="lodge_title_cell">
And is just currently:
.lodge_title_cell {
background-color:#D31B1E;
vertical-align:top;
Thanks.
It is top aligned in firefox. Maybe try adding the attribute to the td tag itself: <td valign="top">
iain331081
Thanks Ray.
