Fwrite from a recordset do while loop
Thread begun 9/04/2009 5:22 am by tom92909 | Last modified 9/04/2009 11:48 am by Eric Mittman | 5674 views | 2 replies |
tom92909Beta Tester
I must be missing something. I'm trying to write an XML file to the server with a loop that reads from a dataset. The write works fine, but I'm not getting any data from my loop. My syntax is wrong I'm sure, but I'm lost on how to make this work. Looking for a friendly helping hand. :)
$fp
fopen('testxml.xml''w');
fwrite($fp'<?xml version="1.0" encoding="UTF-8"?>');
fwrite($fp'<gallery imagesFolder="photos/" thumbnailsFolder="thumbnails/" numRows="3">');
do {
fwrite($fp'<img  src="$row_Recordset1['image1']" width="600" height="400" title="$row_Recordset1['description']"/>');
} while (
$row_Recordset1 mysql_fetch_assoc($Recordset1));
fwrite
($fp'</gallery>');
fclose($fp);
tom92909Beta Tester
I figured it out, below is the solution that creates a functional XML file.
$fp
do {
$imagefile $row_Recordset1['image1'];
$imagename $row_Recordset1['name'];
$imageuser1 $row_Recordset1['description'];
$imageyear $row_Recordset1['year'];
$imageurl $row_Recordset1['image1_link'];
fwrite($fp'<img  src="'.$imagefile.'" width="600" height="400" param="'.$imagename.' '.$imagedescription.' '.$imageyear.'" />');
} while (
fwrite
($fp'</gallery>');
fclose($fp);
Assigning the values to variables before making use of them is a good idea, things can get tricky when you are trying to use the values directly in strings.
