one select update two fields with different values?
Thread begun 7/04/2016 7:54 am by tony | Last modified 7/06/2016 8:15 am by Ray Borduin | 1548 views | 3 replies |
tony
Hi all,
I have a product table contaning 3 fields:
1- id_prod
2- name_prod
3- price_prod
And I have another db table containing the fields nameprod_user and priceprod_user.
I have a form in a page where the user select the product using a select dropdown. The dropdown is populated with a recordset on the product table.
I know how to put the select value in a database field, but in this case I need to put the select value along with another value.
Example:
The select dropdown has the value set to name_prod.
I need to select also the price_prod value.
Then I need to put the two values (name_prod and price_prod in the related db fields: nameprod_user and priceprod_user).
I can do this easily using the good-old ADDT from Interakt (using Multi-field dropdown server behaviour).
How can I do this with data bridge?
TIA
tony
Probably the easiest way is to:
1) Set the value of the select list to the id_prod column
2) Add a recordset to the page to filter based on the the id_prod submitted from the select list
3) Then you can use any other columns from the recordset to set the values for the insert
tony
Hi Ray,
thanks for your reply.
1) ok
2) how can I do this in the same page as the form without reloading the page?
TIA
tony
tony
Originally Said By: tony
  Hi Ray,
1) ok
TIA
tony
nevermind.
I tried it and it works IN THE SAME PAGE without reloading.
Thanks.
tony
