add to cart multiples of 2
Thread begun 6/29/2016 8:42 am by Jamie | Last modified 6/29/2016 4:09 pm by Ray Borduin | 2948 views | 6 replies |
Jamie
Hey Ray
Am trying to get the cart working on that site we discussed the other night - the one where I have a matrix of products and needed to set it up so they could add other items that didnt fall into the matrix.
Have got the 2nd table set up and the backend working fine.
I have the add to cart on the front end 'working' with a couple of probs.
If you add an item to cart on the book-now.php (http://goo.gl/DbREYH) page you then get taken to cart.php - so far so good
Now that you're on the cart.php page, if you add the top item to cart (http://prntscr.com/bmmyps) for some reason it adds 2 items (and multiples of 2 every time you add to cart) to the cart for that line.....
Problem 2.
Clear the cart on the above page. You should still be on cart.php but the original matrix is showing. Add an item to cart there it is adding the item in multiples of 2 and no product name (http://prntscr.com/bmmzz4) - not sure whats happening there - and if you then try to add the extra item (http://prntscr.com/bmn0f2) it adds it (with the product name but again adds in quantities of multiples of 2......
have attached the cart.php and book-now.php pages if it helps
Jamie
You have the add to cart code on the page twice. Lines 109-136 and again on lines 180-207. Remove the first one and it won't add twice.
Jamie
ok thanks. thats working fine but now the 'non matrix' item although is being added once, is not showing the product name - http://prntscr.com/bmqwk0
It looks like you are looping on the ProductMisc table, but inserting from the EB1 table. My guess is that the query isn't returning the results you expect. Try running that query in phpMyAdmin to make sure your joins are correct and that the value for ProductNames and ProductTypeName are what you expect.
Jamie
OK, but when you helped me with the matrix side of things, you set up the EB1 recordset....I get that its using one table (products) and I have added a new one to accommodate the 'other' ptoduct items (products2) but not sure how to incorporate wihtout using a secon atc which clearly doesnt work.....
You could use a second add to cart if you have two add to cart buttons.... just make sure your add to cart buttons have a unique name and the triggers are unique.
I think I advised you on setting up the alternate items but never worked on it with you. I'm getting a bit confused at this point as to what you are trying to do and what is and isn't needed. Maybe you do need two add to carts, but then they need to use different button names. Or did you want two items added to the cart with a single button press?
If the correct products are getting added but just have the wrong name then that would imply just an issue with your SQL statement.
Jamie
EDIT - have actually got it workign now mate
Thanks for getting me on track
