How to add new form elements to an existing Results page inDataAssist
Thread begun 6/28/2016 1:51 pm by tmcbinc99963 | Last modified 7/01/2016 2:33 pm by Ray Borduin | 8882 views | 10 replies |
tmcbinc99963
I'm trying to add a select list and multiple checkboxes inside an existing Results Page Search form. The results form won't recognize any of the search criteria. Returns all results no matter what is selected or entered in the form.
You should avoid using the column name 'date' and any other reserved words as listed here: https://dev.mysql.com/doc/refman/5.5/en/keywords.html
Your select list for date is named "select", but your code is referencing the field as "date".... They have to match, so line:
$WADbSearch1->addComparisonFromList("date","date","AND","=",0);
should be:
$WADbSearch1->addComparisonFromList("date","select","AND","=",0);
or you need to update the select name to "date" to match the php code.
Your checkbox names are "CheckboxGroup1". If you want your users to be able to select more than one, they would have to be named: "CheckboxGroup1[]". If they can only select one then you should be using radio buttons instead.
and then you have a similar issue with the column name reference for that search as well. This code:
$WADbSearch1->addComparisonFromCheck("category","category","".$row_WADAnews['category']  ."","","AND","=","=",0);
should be:
$WADbSearch1->addComparisonFromList("category","CheckboxGroup1","AND","=",0);
Groups of checkboxes act just like multi-select lists.
tmcbinc99963
The column names have been changed and the comparison values have been fixed using the DataAssist Search server behavior and Dynamic List/Menu.
I get the following error message when trying to view page in browser:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '= (news_category LIKE '%AND%') LIMIT 0, 10' at line 1
This pops up when trying to edit the Dynamic List/Menu server behavior. None of the changes are applied when these errors pop up:
ERROR in TagEdit.setOuterHTML
Cannot parse the following value for newOuterHTML:
<option<select name="select" id="select" <>php if (!(sctrcmp("",ucwords($row_news_select['news_date'])))) {echo "selected=\"selected\"";]?>>
<option
While executing applyServerBehavior in DynamicSelectList.htm, a JavaScript error occurred.
File attached.
Line 17 has:
$WADbSearch1->addComparisonFromCheck("news_category","Checkgroup1","".$row_WADAnews['category']  ."","","AND","=","=",0);
It should be:
$WADbSearch1->addComparisonFromList("news_category","Checkgroup1","AND","=",0);
The error in the dynamic select is because your html is out of sync. Your first option tag isn't closed. You have:
<select name="news_select" id="news_select">
     <option value="value" <?php if (!(strcmp("value"ucwords($row_news_select['date'])))) {echo "selected=\"selected\"";} ?>
     <option value="">Select Size</option>
                <option value=""></option>
do {
     <option value="<?php echo $row_news_select['date']?>"<?php if (!(strcmp($row_news_select['date'], ucwords($row_news_select['date'])))) {echo "selected=\"selected\"";} ?>><?php echo $row_news_select['date']?></option>
} while ($row_news_select mysql_fetch_assoc($news_select));
$rows mysql_num_rows($news_select);
  if(
$rows 0) {
mysql_data_seek($news_select0);
$row_news_select mysql_fetch_assoc($news_select);
   </select>
I think it should just be:
do {
     <option value="<?php echo $row_news_select['date']?>" ><?php echo $row_news_select['date']?></option>
  if(
$rows 0) {
   </select>
tmcbinc99963
Decided to go with static select menu, so the Dynamic List/Menu server behavior is deleted.
Still getting the following Mysql error message on page view:
File attached.
Did you close and open your browser after making the page updates? The bad search may have been saved in the session.
To debug further I'd need to debug the page directly. Do you have a url where I can see the problem and FTP access?
tmcbinc99963
Closing and reopening browser got rid of sql error message.
Multiple problems with Search:
When select list comparison value was "itemchecked" it didn't work, but checkboxes did (all checkboxes are <name="CheckboxGroup1" id="CheckboxGroup1">
When select list comparison value was changed to name of select list (news_select) the drop down worked, but not the checkboxes (no results found)
Checkboxes have never worked as a group.
Textfield search has never worked at all (no results found or all results from table).
Viewing page on remote server shows an odd 'table doesn't exist' message.
FTP credentials are in private message and file attached.
Lastly, DW crashes repeatedly when accessing the Search Wizard. The only solution I've found is to edit one item at a time, closing Wizard after each edit.
Your live database only has the columns:
contsize, prod, prodsize, prodtype
There is no table named news.
When using a checkbox group the comparison only has to appear once in the list, but you should name all of your checkboxes with brackets as I explained in post 2.
You should have: name="CheckboxGroup1[]"
I've updated your page, but you will have to update the database so that the table exists before it will work on the live server.
tmcbinc99963
Which file did you fix? It still works as before, even after the Db update.
Try again... you had "Select a Year" as your value for the default option... it needs to be value="" to be ignored. I've updated that as well now.
