DEPRECATED CODE - classes and constructors
Thread begun 6/24/2016 2:36 am by alib75702 | Last modified 6/28/2016 9:27 am by Ray Borduin | 2031 views | 4 replies |
alib75702
I am getting this error even though I have upgraded to the latest version :Methods with the same name as their class will not be constructors in a future version of PHP; gencart_Definition has a deprecated constructor
I just updated the source to address this error. You will have to:
1) Uninstall and Re-Install the eCart Extension
2) Open the eCart object and save it to update the code
3) Upload your cart object file as well as the eCart_Definition.php file from the eCart folder
After doing that the error message should go away.
alib75702
STILL ERRORS
Hi - I have done this but the errors are still there and on inspection of the code the functions and the classes still share the same name?
The latest version should generate the corrected code. There are a lot of other updates other than this in the new version, but you have asked for a refund and I will give it to you under our 15 day money back guarantee.
alib75702
many thanks
