ssl issue
Thread begun 6/20/2016 10:21 am by Sweens | Last modified 6/30/2016 10:29 am by Ray Borduin | 4915 views | 11 replies |
Sweens
ssl issue
I've recently installed ssl on the server and the kae's file manager displays everything OK, but when you try to embed a picture or link to a file, a javascript error message appears at the bottom of the window, basically saying no file is selected.
It worked fine before ssl!
Is there a quick fix?
Many thanks
Chris
What is the url? I'll see if I can spot the problem. I'll need login information to see the problem and probably FTP access if you want me to debug and try to fix it.
Sweens
pm
Can I see a copy of the 2-message-to-members.php page? It appears the issue may be that the kfm is opening with http:// and you are on an https:// page. The solution may be to simply update the link to the file manager to use https as well.
Sweens
IS THAT THE LINE IN THE HEAD SECTION:
<?php require_once("../../webassist/ckeditor/ckeditor.php"); ?>
if I change this to the actual path, https://etc/webassist/etc I get an error message on the page and it doesn't load at all.
No the line you would change is line 169. Try that and see if it helps.
Sweens
I re-read your message, found the appropriate part and added the 's'. thanks for pointing it out.
Cheers
Chris
Sweens
Hi Ray
A related problem; Windows 7 users are reporting that when they click the 'browse server' button, they get redirected to the login page - as if they aren't already logged in.
Is there a page that needs updating to use https:// - I've been through all the files in webassist/kfm
I haven't been able to replicate this with any other OS - but a few people have now reported this.
Cheers
Chris
Please attach a copy of the page and I can suggest potential solutions.
Sweens
Hi Ray
Many thanks
Chris
