Binding recordsets to eCart
Thread begun 6/20/2016 1:34 am by markdoyle87077 | Last modified 6/20/2016 11:35 am by Ray Borduin | 1532 views | 3 replies |
markdoyle87077
When binding a recordset to eCart on my localhost everything works fine. However when I run this on my live server $dmbc_po_itemSupplier = "".($rs_po->getColumnVal("supplier")) .""; does not bind
$rs_po = new WA_MySQLi_RS("rs_po",$dmbc_database,0);
$rs_po->setQuery("SELECT itemnumber, description, order_quantity, cost, buying_quantity, supplieritemnumber, packingorder, supplier FROM products WHERE supplier = ? AND stockstatus = 'Online' AND (stock-packed-customer_back_orders-pending_online_orders) + ((onorder) * (buying_quantity / selling_quantity)) <= reorder AND visible = 1 ORDER BY packingorder, itemnumber");
$rs_po->bindParam("s", "".(isset($_POST['supplier'])?$_POST['supplier']:"") ."", "-1"); //colname
$rs_po->execute();
// WA eCart Get Info From MySQLi RS
if (("" == "") && $rs_po->TotalRows > 0) {
$Redirect_redirStr="";
if (function_exists("rel2abs")) {
$Redirect_redirStr = $Redirect_redirStr?rel2abs($Redirect_redirStr,dirname(__FILE__)):"";
while(!$rs_po->atEnd()) {
$dmbc_po_itemID = floatval("".($rs_po->getColumnVal("itemnumber")) ."");
$dmbc_po_itemName = "".($rs_po->getColumnVal("itemnumber")) ."";
$dmbc_po_itemDescription = "".($rs_po->getColumnVal("description")) ."";
$dmbc_po_itemThumbnail = "0";
$dmbc_po_itemWeight = floatval("0");
$dmbc_po_itemQuantity = floatval("".($rs_po->getColumnVal("order_quantity")) ."");
$dmbc_po_itemPrice = floatval("".($rs_po->getColumnVal("cost")) ."");
$dmbc_po_itemPack = floatval("".($rs_po->getColumnVal("buying_quantity")) ."");
$dmbc_po_itemSupplierItem = "".($rs_po->getColumnVal("supplieritemnumber")) ."";
$dmbc_po_itemLocation = floatval("".($rs_po->getColumnVal("packingorder")) ."");
$dmbc_po->AddToCart(1, "", $dmbc_po_itemID, $dmbc_po_itemName, $dmbc_po_itemDescription, $dmbc_po_itemThumbnail, $dmbc_po_itemWeight, $dmbc_po_itemQuantity, $dmbc_po_itemPrice, $dmbc_po_itemPack, $dmbc_po_itemSupplierItem, $dmbc_po_itemLocation, $dmbc_po_itemSupplier);
$rs_po->moveNext();
if ($Redirect_redirStr != "") {
$dmbc_po->redirStr = $Redirect_redirStr;
$rs_po->moveFirst();
$rs_po->Index = 0;
Add code to debug the recordset after it opens like:
var_dump($rs_po);
die();
The result might give you the necessary clues to figure out at least whether the issue is with the recordset or the add to cart.
Then try running the SQL statement in the recordset in phpMyAdmin directly to see if there is an issue with the database.
markdoyle87077
I have run the php code and the array looks fine
object(WA_MySQLi_RS)#3 (19) { ["Name"]=> string(5) "rs_po" ["Connection"]=> object(mysqli)#1 (19) { ["affected_rows"]=> int(-1) ["client_info"]=> string(75) "mysqlnd 5.0.10 - 20111026 - $Id: c85105d7c6f7d70d609bb4c000257868a40840ab $" ["client_version"]=> int(50010) ["connect_errno"]=> int(0) ["connect_error"]=> NULL ["errno"]=> int(0) ["error"]=> string(0) "" ["error_list"]=> array(0) { } ["field_count"]=> int(8) ["host_info"]=> string(20) "localhost via TCP/IP" ["info"]=> NULL ["insert_id"]=> int(0) ["server_info"]=> string(16) "5.1.73-community" ["server_version"]=> int(50173) ["stat"]=> string(137) "Uptime: 443343 Threads: 1 Questions: 14696 Slow queries: 0 Opens: 472 Flush tables: 1 Open tables: 12 Queries per second avg: 0.33" ["sqlstate"]=> string(5) "00000" ["protocol_version"]=> int(10) ["thread_id"]=> int(536) ["warning_count"]=> int(0) } ["CurrentPage"]=> string(44) "/php/admin/purchasing/new_purchase_order.php" ["Statement"]=> string(349) "SELECT itemnumber, description, order_quantity, cost, buying_quantity, supplieritemnumber, packingorder, supplier FROM products WHERE supplier = ? AND stockstatus = 'Online' AND (stock-packed-customer_back_orders-pending_online_orders) + ((onorder) * (buying_quantity / selling_quantity)) <= reorder AND visible = 1 ORDER BY packingorder, itemnumber" ["ParamTypes"]=> string(1) "s" ["FilterValues"]=> array(0) { } ["ParamValues"]=> array(1) { [0]=> string(6) "Belbal" } ["Results"]=> array(7) { [0]=> array(8) { ["itemnumber"]=> string(5) "10255" ["description"]=> string(35) "Crystal Blue Latex Round 5in/12.5cm" ["order_quantity"]=> int(10) ["cost"]=> string(4) "1.81" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(18) "1008002-100 D5 033" ["packingorder"]=> int(620) ["supplier"]=> string(6) "Belbal" } [1]=> array(8) { ["itemnumber"]=> string(5) "10257" ["description"]=> string(36) "Crystal Clear Latex Round 5in/12.5cm" ["order_quantity"]=> int(10) ["cost"]=> string(4) "1.81" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(18) "1008002-100 D5 038" ["packingorder"]=> int(620) ["supplier"]=> string(6) "Belbal" } [2]=> array(8) { ["itemnumber"]=> string(5) "10259" ["description"]=> string(36) "Crystal Green Latex Round 5in/12.5cm" ["order_quantity"]=> int(10) ["cost"]=> string(4) "1.81" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(18) "1008002-100 D5 035" ["packingorder"]=> int(620) ["supplier"]=> string(6) "Belbal" } [3]=> array(8) { ["itemnumber"]=> string(5) "10260" ["description"]=> string(37) "Crystal Orange Latex Round 5in/12.5cm" ["order_quantity"]=> int(10) ["cost"]=> string(4) "1.81" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(18) "1008002-100 D5 037" ["packingorder"]=> int(620) ["supplier"]=> string(6) "Belbal" } [4]=> array(8) { ["itemnumber"]=> string(5) "10269" ["description"]=> string(35) "Pastel Black Latex Round 5in/12.5cm" ["order_quantity"]=> int(10) ["cost"]=> string(4) "1.72" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(18) "6061001-100 D5 025" ["packingorder"]=> int(620) ["supplier"]=> string(6) "Belbal" } [5]=> array(8) { ["itemnumber"]=> string(5) "10289" ["description"]=> string(36) "Pastel Yellow Latex Round 5in/12.5cm" ["order_quantity"]=> int(10) ["cost"]=> string(4) "1.72" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(18) "6061001-100 D5 006" ["packingorder"]=> int(620) ["supplier"]=> string(6) "Belbal" } [6]=> array(8) { ["itemnumber"]=> string(5) "10012" ["description"]=> string(41) "Pastel Leaf Green Latex Round 11in/27.5cm" ["order_quantity"]=> int(22) ["cost"]=> string(4) "2.78" ["buying_quantity"]=> int(100) ["supplieritemnumber"]=> string(19) "1008001-100 B95 011" ["packingorder"]=> int(630) ["supplier"]=> string(6) "Belbal" } } ["Index"]=> int(0) ["MaxRows"]=> int(0) ["PageNum"]=> int(0) ["PrevPage"]=> int(0) ["NextPage"]=> int(0) ["StartLimit"]=> int(0) ["StartRow"]=> int(1) ["LastRow"]=> int(7) ["TotalRows"]=> int(7) ["TotalPages"]=> int(0) ["QueryString"]=> string(18) "&totalRows_rs_po=7" }
I have also run the sql directly on the database and the records are returned correctly so this leads me to think the issue is with the add to cart.
Yes. The recordset appears to be returning results, so the issue has to be with the add to cart.
What exactly happens when you are trying? Is it possible you haven't uploaded the latest cart object from your localhost and that column doesn't exist yet? Try uploading the WA_eCart folder and see if that fixes it.
