How can I convert my entire mysql data base to mysql lite? I can't find any reference to this.
Thread begun 6/16/2016 1:54 am by david331670 | Last modified 6/17/2016 10:42 am by Ray Borduin | 2210 views | 4 replies |
david331670
I want to convert my old mysql data base to the new mysql lite version. this would be the entire data base.
Thanks for your help
David
You would have to update your php pages, not your database. The database is the same. This could be a very complicated process depending on the complexity of your site. If you use MySQLi instead of mysql lite you could get help from our MySQLi Server Behaviors extension.
david331670
Hi
I have MySQLi Server Behaviors extension. I unfortunately not been very active investigating the updated MySQLi requirements. I thought the data base needed changing as well as the php pages. I should really update the entire site. If I redo all the pages with DW 2015 in conjunction with MySQLi Server Behaviors extension., will this rewrite the code correctly?
David B
I wouldn't bother updating existing sites. I'd start developing new sites with MySQLi. Old MySQL sites will likely continue to run for a decade and going back to re-do them is probably more work than it is worth at this point. Plan for the future with MySQLi, but don't revisit older sites in my opinion.
david331670
Thanks for that, I just goes to prove "if you stand still, you end up going backwards very quickly".
Time to take the plunge.
Thanks for the advice.
David B
