Insert and Update in one form?
Thread begun 9/04/2009 1:10 am by Daryl | Last modified 9/04/2009 12:54 pm by Jason Byrnes | 2505 views | 3 replies |
DarylBeta Tester
First question....
Is it possible to create an insert form that will insert data into table a but will update table b?
Second question....
Is it possible to update all data in one table column? ie update all records in a column from a 1 to a 0.
Just want to know if it is pheasable before I get stuck in to trying to build it.
Many Thanks
Sure, you could use both and insert and update server behavior on the same page. Just make sure that the insert does not have a redirect so the update can happen.
You can update all records in a DB using a simple update statement that does not include a where clause. For Example:
UPDATE table_name SET column1=1
Will update column1 in every record in the DB to a value of 1
DarylBeta Tester
Perfect!
Thanks Jason
You're welcome.
