square payment gateway
Thread begun 6/15/2016 12:06 pm by chiakioda428401 | Last modified 4/24/2018 10:21 am by Ray Borduin | 6395 views | 8 replies |
chiakioda428401
just a question. is there any way to integrate the square payment gate into ecart?
I know it support paypal and other payment gateways, but i dont see the square gateway.
Is it possible to use in the ecart?
Yes it is possible. You would just follow the square documentation on how to do it. We could help with something like that in a premier support ticket.
chiakioda428401
thank you.
I will contact you when i need help.
graham
Did you happen to integrate Square successfully?
I am thinking about getting away from Paypal and would love to know if you integrated Square successfully? Paypal is causing me waaaayyyy more problems of late - so many users having issues completing transactions on the back end (nothing to do with Webassist coding) .. I end up invoicing them with Square.
If you are still in the system, could you let me know how it went? Otherwise, I would likely ask Ray for his thoughts on helping fast-track integration ... thanks, Ray!!
We did this together in a 1 hour premier support session. If you have it working with another payment gateway like authorize.net or paypal direct payments, then swapping out the code for square is pretty easy.
First I would set up a test page outside of the site to get a working square transaction to make sure your credentials are all in place. Then I would move that code into your checkout process and swap out the test values with the references to your checkout form and ecart contents.
graham
WOW ... thanks for the quick advice, Ray. I remain a HUGE Ray Borduin fan! I am a week away from being able to try this, and will contact you if I need your help.
Ben Pleysier
If you have succeeded in getting the payment to work, please help me with the following settings
AuthNet_PHP.php:
I have set this to: curl_setopt($ch, CURLOPT_URL,"https://js.squareup.com/v2/paymentform");. Is this correct?
gateways.php
I have set this to:
$WA_Authorize_Net_API_Credentials_Login_ID = " Application ID ";
$WA_Authorize_Net_API_Credentials_Transaction_Key = " Personal Access Token ";
Unfortunately I cannot get it to work, please help
That isn't going to work. Each of the variables being passed have to be updated as well. It will use completely different variable names.
Ben Pleysier
OK, it seemed too easy the way that I was suggesting. Will spend more time on it. Thank You Ray
