The store values behavior does not save the variable
Thread begun 6/12/2016 6:37 pm by JBWebWorks | Last modified 6/14/2016 12:08 pm by Ray Borduin | 3317 views | 8 replies |
JBWebWorks
Using login form with MySQLI (just purchased) and the store values does not save. (trying to save admin_ID)
Also when I go back into the server behavior to check it writes code for the table as this "`admin`"
with the single quote inside the double quotes?
santius355196
How are you testing if the session variables are set. Create a page with this:
@session_start();
var_dump($_SESSION);
Then visit that page after login and see if the session variables are set. If they aren't it is probably a configuration issue on the server with the session_save_path setting in in the php.ini file. Your hosting provider could probably look into it and get that resolved for you.
JBWebWorks
I can see that the session is not written in the code when using the Store Values form from the MySQLI Login User Server Behavior. The screen shot shows that nothing is saved when filling in the Save in Session As text field.
I had to hand code a Session as
@session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["newsession"] = "".((isset($_POST["username"]))?$_POST["username"]:"")  ."";
You have to type in a value for "Save in session as" for each field you want stored. You don't have any specified to be stored in yours.
JBWebWorks
Ray,
I have typed in admin_ID for the column, admin_ID and clicked OK, but nothing happens, except it changes this
$Authenticate->Name = "admin";
  $Authenticate->Table = "admin";
to this
  $Authenticate->Table = "`admin`";
Please post a US phone number or Skype contact information and I'll debug this with you over the phone in a screen sharing session.
JBWebWorks
See PM
This appears to be an issue with CS5.5. We were able to find a solution in a screen sharing session.
JBWebWorks
Ray,
Thanks for your quick response and solving the interface issue!
I look forward to the Databridge upgrade including use with MYSQLi. Great products from Webassist!
