Problem records being returned
Thread begun 6/11/2016 1:54 am by markdoyle87077 | Last modified 7/07/2016 7:22 pm by Ray Borduin | 7825 views | 14 replies |
markdoyle87077
I have set up my search page and when I search for 0070 8 foil balloons are returned. The recordset I am using for this is:
$rs_foil
= new WA_MySQLi_RS("rs_foil",$dmbc_database,0);
$rs_foil->setQuery("SELECT products.id, products.itemnumber, products.description, products.categories, products.category_type, products.status, products.type, products.productdescription, products.typename, products.selling_quantity, products.price, products.image, products.imagelarge, products.volumediscount, products.supplier, products.supplierlogo, products.stock, products.onorder, products.packed, products.customer_back_orders, products.pending_online_orders, products.visible, products.product_arrival_date, special_prices.price AS special_price FROM products LEFT OUTER JOIN special_prices ON products.itemnumber = special_prices.itemnumber AND special_prices.userdetails_id = ? WHERE visible = 1 AND category_type='Foil Balloons' AND (products.itemnumber LIKE ? OR products.supplieritemnumber LIKE ? OR description LIKE ? OR keywords LIKE ? OR supplier LIKE ?) ORDER BY description ASC");
$rs_foil->bindParam("i""".($rs_customer->getColumnVal("id"))  ."""-1"); //colname
$rs_foil->bindParam("c""".(isset($_SESSION['keywords'])?$_SESSION['keywords']:"")  ."""-1"); //colname1
$rs_foil->bindParam("c""".(isset($_SESSION['keywords'])?$_SESSION['keywords']:"")  ."""-1"); //colname2
$rs_foil->bindParam("c""".(isset($_SESSION['keywords'])?$_SESSION['keywords']:"")  ."""-1"); //colname3
$rs_foil->bindParam("c""".(isset($_SESSION['keywords'])?$_SESSION['keywords']:"")  ."""-1"); //colname4
$rs_foil->bindParam("c""".(isset($_SESSION['keywords'])?$_SESSION['keywords']:"")  ."""-1"); //colname5
$rs_foil->execute();
I then have an option to sort these by size/type using the following URL:
http://www.dmballooncompany.com/php/gb/registered/products/category_search.php?category=0070&category_type=Foil Balloons
The problem is no products are returned. The recordset I am using for this is below. It is modified version of the recordset at the top of the page and I am cannot seem to work out why no products are returned. What is even more strange is that if I search for love 82 products are returned and then when I click the URL to sort by size/type 82 products are shown.
$rs_products
= new WA_MySQLi_RS("rs_products",$dmbc_database,0);
$rs_products->setQuery("SELECT products.id, products.itemnumber, products.description, products.categories, products.category_type, products.status, products.type, products.productdescription, products.typename, products.selling_quantity, products.price, products.image, products.imagelarge, products.volumediscount, products.supplier, products.supplierlogo, products.stock, products.onorder, products.packed, products.customer_back_orders, products.pending_online_orders, products.visible, products.product_arrival_date, special_prices.price AS special_price FROM products LEFT OUTER JOIN special_prices ON products.itemnumber = special_prices.itemnumber AND special_prices.userdetails_id = ? WHERE visible = 1 AND category_type=? AND (products.itemnumber LIKE ? OR products.supplieritemnumber LIKE ? OR description LIKE ? OR keywords LIKE ? OR supplier LIKE ?) ORDER BY type, description ASC");
$rs_products->bindParam("i""".($rs_customer->getColumnVal("id"))  ."""-1"); //colname
$rs_products->bindParam("s""".(isset($_GET['category_type'])?$_GET['category_type']:"")  ."""-1"); //colname1
$rs_products->bindParam("c""".(isset($_GET['category'])?$_GET['category']:"")  ."""-1"); //colname2
$rs_products->bindParam("c""".(isset($_GET['category'])?$_GET['category']:"")  ."""-1"); //colname3
$rs_products->bindParam("c""".(isset($_GET['category'])?$_GET['category']:"")  ."""-1"); //colname4
$rs_products->bindParam("c""".(isset($_GET['category'])?$_GET['category']:"")  ."""-1"); //colname5
$rs_products->bindParam("c""".(isset($_GET['category'])?$_GET['category']:"")  ."""-1"); //colname6
$rs_products->execute();
Any ideas?
santius355196
I don't see the issue in the recordsets themselves...
I'd start by adding some debug code and see if you can spot the problem in the SQL statement on the page that isn't working.
Add this to the page:
$rs_products->debugSQL()
See if that looks right. If it does, maybe it is a problem where they are displayed and not the recordset itself. If you attach a copy of the search and category_search pages I can take a look and see if I can spot the problem that way.
markdoyle87077
Thank you for taking the time to look.
Did the debug SQL look like what you expected? Maybe the cookie isn't getting set properly or that isn't the right information in the database.
I'll need to debug to know for sure and to do that I'd need login information to get the cookie set and FTP access to add my own debug code.
markdoyle87077
See pm
I can't seem to connect with that FTP information. Please verify it works for you and doesn't have any typos. Also make sure there aren't any additional settings I need to use in order to connect.
markdoyle87077
Hi Ray, I have incoming FTP sessions set to use only my IP. Do you have a static IP I can add to the firewall?
see private area for my IP
markdoyle87077
Hi Ray, Thought I had replied earlier but obviously not. I have added your IP to the firewall so you should be able to connect now.
I still can't seem to connect with that FTP information. What was the result when you added this debug code to the page:
