jquery validation on form submit
Thread begun 6/08/2016 10:24 am by bpitcher32 | Last modified 6/10/2016 10:39 am by Ray Borduin | 4048 views | 8 replies |
bpitcher32
Changed from spry to jquery validation for my checkout.php page. When an error is found an error popup appears to inform the user of an error. For example: zipcode is entered as xxxxx-xxxx. The 9 digit zip code does not compute a USPS shipping cost, only a 5 digit zipcode does.This problem usually occurs when the autofill is used on the form
Even though the error message is visible, when the submit button is clicked the the page is submitted and confirm2.php is added for customer to complete their credit card information - but - there are no shipping costs calculated. I am sure the problem lies in the form submit button but I have not been able to figure out the correct configuration. I have attached the checkout.php page for you. I would appreciate your guidance.
Thanks - Brian
Try dumping the session on a test page like:
@session_start();
var_dump($_SESSION);
View source on the page to make it readable. Go through the process until the point where you would expect to see the shipping costs (confirm page) and then visit the test page in another window.
That should include any communication with your shipping service and any errors that might lead you to the solution. If you post FTP details and a URL to reproduce the problem I could take a look for you.
bpitcher32
Thank you for you prompt response.
I updated the paymentoptions.js file to better handle jquery validation changes. It should work for you now.
bpitcher32
Ray thank you. The error we were having is gone. The validation works correctly. Pressing the submit button does not override the error. The error must be fixed before the submit button works. BUT there is now a new error. After the form has been validated and the credit card information has been entered I get an error message from authorize.net. Code 270 - Line item 1 is invalid. Would appreciate you thoughts - Brian
What items did you have in the cart? This is usually an error with an invalid character in the item name. It worked in my test, but most likely because I had a different item in the cart. If you reproduce the error and tell me what item I need to add I can look into it further.
bpitcher32
I received the error when I tried to buy https://www.the-christening-corner.com/Product/Accessory/Catholic-Bible/?ID=345 which has an ampersand in the title. The purchase went through correctly when I tried to buy https://www.the-christening-corner.com/Product/Accessory/Catholic-Bible/?ID=343. Is an ampersand one of the invalid characters. What are the others and I will remove them from the titles of each item?
I think just ampersands... that was going to be my guess and it is the only one I know of offhand.
bpitcher32
Ray,
Thank you for all of your help. I will download the new paymentoptions.js file into my Dreamweaver local files and we will live "happily every after" hopefully.
Again thank you very much! Brian
