my mysql statement doesnt return correct results
Thread begun 6/01/2016 4:51 pm by Christopher West | Last modified 6/01/2016 9:44 pm by Ray Borduin | 717 views | 1 replies |
Hi there on my product listing page I want to show how many times a product is displayed in a category.
So I am using the following SQL statement in the rsCatalog
But the bottom 5 records should be displaying 1 (if you look at the screenshot for the catalog table you will see that the bottom 5 records only occur once. Waht could be wrong with my SQL statement.
$rsProducts
= new WA_MySQLi_RS("rsProducts",$ecartdb,0);
$rsProducts->setQuery("SELECT * FROM products");
$rsProducts->execute();?>
$rsCatalog
= new WA_MySQLi_RS("rsCatalog",$ecartdb,1);
$rsCatalog->setQuery("select CatalogProductID, count(*) as assigned FROM catalog GROUP BY CatalogProductID");
$rsCatalog->execute();
here is some of the code for the loop:
<?php if ($rsProducts->TotalRows 0) { // Show if mysqli recordset not empty ?>
<td><?php echo($rsCatalog->getColumnVal("assigned")); ?></td>
  $rsProducts
->moveNext();
$rsProducts->moveFirst(); //return RS to first record
Chris
You aren't looping through the $rsCatalog table, so it will only show the first row. I think you want to use a nested select and a single recordset in this case like:
$rsProducts
$rsProducts->setQuery("SELECT *, (select count(*) as assigned FROM catalog WHERE CatalogProductID = ProductID) AS assigned FROM products");
