Problen upload images
Thread begun 6/01/2016 5:05 am by QuiruNet | Last modified 6/09/2016 12:28 pm by Ray Borduin | 4580 views | 11 replies |
QuiruNet
This days, i have problems to upload images, sometimes it is stock for hours trying to upload, like de attachments y send you. Can you help me. thanks
I'll need a url to reproduce the problem and FTP access to debug. I may also need the images you are uploading if they are significant to reproducing the problem. I imagine it is a particular image that is too large causing an out of memory error. The solution may be to increase the available memory on the server using the php.ini file.
QuiruNet
info
All images are no to large, about 160 KB each, we upload 120 images, in four steps (480 images, sometimes more, but always upload 120 images each step)
php.ini - memory_limit: 256M
There is some sort of issue going on with the server. Do you have access to error logs? It appears the entire server is going down when this happens. I can't access any pages and things start acting very strangely. I'd contact your hosting provider and see if you can get more information about the exact error and why the site is going down.
The image upload accesses hundreds of pages quickly, but it appears to me that accessing any page multiple times will bring the site down. I see it is failing on the line:
@session_start();
so it has something to do with the server session management, but it appears to be an issue your hosting provider will need to address.
QuiruNet
i send you the log
i hope you can see something,...it never happen....but now, every time the client up load the gallery, it happen. Thank a lot.
I'd contact your hosting provider and see if they can help. I don't see the problem from these logs, but it appears to be a server configuration issue of some sort and not an issue with your files themselves. If it was an issue with your files it would have always happened. If it just started happening recently then that implies the hosting company made an update recently and they could potentially be able to fix it for you.
QuiruNet
info
Thank Ray, i will speak with the hosting.
But, my client upload the files in safari, and that the problem happend...when the uplodad is waiting in some file....the safari freeze....but i try in firefox...and it wait .... but in the end show the error, that some times can upload a specific photo. My question is.....we can short the time....if the gallery has a problem...with a photo is uploading....because the time it is processing is abou 10 minutes ore more ....Thanks
The issue is with the site session failing. I can't see how to shorten the time... perhaps set the session timeout to a shorter period, but that might cause other issues.
The real solution is to keep it from failing in the first place. Hopefully the hosting company can get it resolved.
QuiruNet
session failing
But the session failing, if i remove the session from the page addimages?? remove: ../WA_SecurityAssist/Helper_PHP.php, i will work?.
Other thing, when sometimes, it give a error to upload an image, and the client has to wait over 10 minutes...the thing i find this code:
@error_reporting(E_ALL);
@set_time_limit(0);
@ini_set('display_errors', 'on');
@ini_set('max_execution_time', 0);
@ini_set('memory_limit','64M');
@ini_set('gd.jpeg_ignore_warning', 1);
if i change this line @ini_set('max_execution_time', 0);, change 0 to 2 minutes, it will make a different than the client doest will wait that 10 minutes each error. Thanks
No I think the issue is that the session isn't closing properly and then it will wait for the session to close before allowing access to the page.
You might be able to lower the session time limit to get around the problem... but again this is a server issue that should be addressed by the server admin instead of working around it.
Another solution might be to not use the session, but to do that you would have to store some of the necessary session variables somewhere else, or pass them into the page through the url.
