Column 'ID' cannot be null
Thread begun 5/31/2016 11:40 pm by Kumel | Last modified 6/02/2016 9:52 pm by Ray Borduin | 7544 views | 13 replies |
Kumel
Column 'JobID' cannot be null
i m getting error as: Column 'JobID' cannot be null
This happened as i made some changes on page.
Error appears after submitting the page.
Page attached.
On local server server pointed at:
Notice: Undefined index: JobAdded in /*/**/**/htdocs/**/**/add-job-step-2.php on line 191
You probably need to go into your database and update the table so that the JobID is an Auto-Increment column and will get a value automatically.
Kumel
JobID is actually stored in many insert multiple recordsets using session jobid. so. JobID is already in Auto Incre
Maybe the issue is that the Session variable isn't stored properly in some cases? Can you figure out which table insert is causing the error? Try writing the session variable value to the page to make sure it is set properly. That error implies that either you are inserting into the Jobs table and the JobID column isn't set as autonumber, or you are inserting into another table and the value of JobID is blank.
Kumel
i checked all. all seems fine. i m using session JobAdded for all. so JobAdded is JobID which is inserted 1st into jobs table.. then Session JobAdded (JobID) is added to other multiple insert.
Which insert is failing? That will tell you where the error is. When you see the error is the new Job inserted? Are any of the multiple inserts completed?
Kumel
The first single record insert is not working. so all the rest also are not adding.
Error as: Notice: Undefined index: JobAdded in /Applications/*****/add-job-step-2.php on line 191
LINE 191: $WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("LockOutChecked", $WA_multipleInsertCounter) ."" . $WA_AB_Split . "".$_SESSION['JobAdded'] ."";
Kumel
Alright i had inserted Progress bar ever since that it is causing problem.
I removed following:
<div id="formstep21_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('formstep21', 'formstep21_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="formstep21_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="../webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
Then form works. but i do require progress bar here.
Change the trigger for the insert to match the triggers for the multiple insert.
Button press triggers don't work with <button> elements when using the progress bar in the version you have installed.
This issue is fixed in the latest version of Data Bridge if you reinstall. I have also attached the newer copy of the .js file that fixes this problem if you don't want to update the trigger or change your <button> elements to <input type="button"> elements.
Kumel
i replaced the file. stil the same.
Anyways i tested without progress bar the form submitted but one of the multiple records are not inserting.
& that is not appearing on server behaviour:
This is what it is:
// WA DataAssist Multiple Inserts
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_loopedFields = array("Emp");
$WA_connection = $con1;
$WA_table = "MutipleEmployees";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "EmployeeID|JobID";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL";
$WA_insertIfNotBlank = "Emp";
$WA_connectionDB = $database_con1;
$WA_multipleInsertCounter = 0;
while (WA_AB_checkMultiInsertLoopedFieldsExist($WA_loopedFields, $WA_multipleInsertCounter)) {
if ($WA_insertIfNotBlank == "" || WA_AB_checkLoopedFieldsNotBlank(array($WA_insertIfNotBlank), $WA_multipleInsertCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("Emp", $WA_multipleInsertCounter) ."" . $WA_AB_Split . "".$_SESSION['JobAdded'] ."";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$WA_multipleInsertCounter++;
if ($WA_redirectURL != "") {
