Unwanted extra line above menu
Thread begun 9/03/2009 8:14 pm by question382438 | Last modified 9/08/2009 1:10 pm by Jimmy Wu | 4561 views | 3 replies |
question382438
I've successfully created several menus using Menu Writer. However, this menu is causing some problems:
nutContact.asp
1. extra line is added above the menu.
2. text has unwanted underline. (e.g., Nutcracker, policies, calendar, etc)
Your help is greatly appreciated.
TIA,
CH
Jimmy Wu
In your main.css, you have the links set to text-decoration: underline. Since the menus use links, they are underlined as well. You will need to change these two lines of your css file:
.link { font: 10px/14px Verdana, Arial, Helvetica, sans-serif; color: #ffffff; text-decoration: underline; font-weight:bold; }
.link:hover { font: 10px/14px Verdana, Arial, Helvetica, sans-serif; color: #cccccc; text-decoration: underline; font-weight:bold; }
to look like this:
.link { font: 10px/14px Verdana, Arial, Helvetica, sans-serif; color: #ffffff; text-decoration: none; font-weight:bold; }
.link:hover { font: 10px/14px Verdana, Arial, Helvetica, sans-serif; color: #cccccc; text-decoration: none; font-weight:bold; }
I'm not sure what you mean by having a line above the menu. Are you referring to the space between the menu and the header?
question382438
I removed the unwanted line on top of the navbar. But the underlined link is still a problem.
In DW design view mode, the underline doesn't show up. Here's a snapshot in DW.
Also, I use the same main.css for another menuwriter navbar and the links are not underlined.
Any other advice for removing the unwanted underline?
Jimmy Wu
The css code in the main.css is overwriting the css from the menu.css file. You can try hard coding the text-decoration to be none for the menu items if you want, but the easiest way to alleviate the issue is to change those lines in the main.css.
