Getting the next ID before insert
Thread begun 5/30/2016 9:14 am by Christopher West | Last modified 6/01/2016 10:53 am by Ray Borduin | 2461 views | 3 replies |
Hi quick question. I want to get the ID of the next record before inset.
Reason, I want to create a product record which upon form submit will store the ID of the record in another table for product images, now since the product hasnt been created until the form submit is pressed, I need a way of getting the next record ID. What would be the syntax for this?
In essence, I need, [latest ProductID]+1
Chris
Can't you store the images after the insert? Using latest ProductID +1 may not work consistently. The best solution is to do the image inserts after the master insert. The newly inserted ID will be saved in the session and can be referenced on the same page after the insert for the image inserts.
Hi Ray, ok my follow on question to this would (I haven't tested it yet).
So from your solution, if I have 1 HTML form on the page and the form elements are separated as tabs, And I am storing the data into 2 different database tables, does this mean that I can have 2 separate webassist insert server behaviors triggering on the same form submit. but the image insert will be triggered first, followed by the second inset for the main data?
Following on from this, is it possible to allow many image inserts on the same page (for additional product images) what I mean is, once the client add one image filename to the form, then another input box appears via javascript, and this keep repeating as much as the client wishes. then on form submit, the insert for images will insert many records at the same time?
Chris
I don't know your database structure, but I'm assuming you want to have the main record ID when you insert into the images table, so you would have two inserts, but you would insert the main table data first and then insert the images after once you have the ID from the main table.
Yes you could do multiple inserts in this way, but it would require some hand coding in both javascript and php to pull off.
