jQuery accordions on framework pages
Thread begun 5/27/2016 2:08 pm by Jason | Last modified 6/01/2016 9:29 pm by Ray Borduin | 3497 views | 8 replies |
Jason
I converted a Dreamweaver template that I was using on a bunch of pages into a Theme with framework builder. Everything is working correctly, except for pages that contain the jQuery accordions. On those pages the body content loads before the theme for some reason, and I get a jQuery not defined error.
Can I see the url of the page you are having difficulty with? It is probably an issue with repeated jquery code or code in the wrong order.
Jason
See private message
You don't have the jquery library loaded on this page...
The page actually has multiple <html>, <head>, and <body> tags.
I'd have to look at the page and how you are loading the plugins to figure out where it is going wrong.
Jason
I'm attaching 3 pages.
index.php - is the page you viewed that isn't working correctly.
new_series.php - is a page in the same folder as index.php and it uses the same theme files. It works correctly, but doesn't contain an accordion.
alf_cms_blank.dwt.php - is the template that the theme is using (This is where the basic jquery files are being called in).
I know what you're referring to regarding the multiple html, body... tags. It only occurs on the pages that use an accordion. It appears that the page loads the theme nested inside of the accordion div for some reason.
Your index page doesn't have an </body> tag. It looks like an issue with the /Templates/Themes/alf_cms_blank_fw_theme.dwt.php file itself.
Jason
The /Templates/Themes/alf_cms_blank_fw_theme.dwt.php is attached. It doesn't have much to it. I'm assuming the theme is pulling the actual template info from /Templates/alf_cms_blank.dwt.php, which I attached to my previous reply.
The body tag for the index file is on line 53 of index.php. It's part of the template code, but it's being called in the same as the body tag on new_series.php (line 143).
Your theme code got placed in the middle of the page and it needs to be on the top.
Move the code from lines 151-157 above the <html> tag around line 30 and it should fix this issue.
Jason
Yup! That fixed it. Thanks Ray. Not sure why, but it did that on every single one of my pages that have the jQuery accordion. Might be a bug or might just be me and my random issues. lol Anyway, thanks for the excellent help as always!
