Update Where IN integer list
Thread begun 5/25/2016 3:12 pm by Jason | Last modified 5/11/2017 12:35 pm by Ray Borduin | 5863 views | 16 replies |
Jason
I'm getting the following error
UPDATE access_userlogin SET sg_leader = ? WHERE userlogin_id IN ?
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '?' at line 1
if (!function_exists('getAllColumns')) {
    function getAllColumns($rs,$col) {
          $allColumns = "";
          for ($x=0; $x<sizeof($rs->Results); $x++) {
                    if ($allColumns) $allColumns .= ", ";
            $allColumns .= $rs->Results[$x][$col];
          return $allColumns;
$updated_leaders = new WA_MySQLi_RS("updated_leaders",$local_i,0);
$updated_leaders->setQuery("SELECT sg_smallgroup.leader FROM sg_smallgroup WHERE sg_smallgroup.smallgroup_start_date < ? AND (sg_smallgroup.smallgroup_end_date > ? OR sg_smallgroup.smallgroup_end_date IS NULL)");
$updated_leaders->bindParam("t", "".(date('Y-m-d', strtotime("-2 weeks")))  ."", "-1"); //WAQB_Param1
$updated_leaders->bindParam("t", "".(date('Y-m-d', strtotime("+2 weeks")))  ."", "-1"); //WAQB_Param2
$updated_leaders->execute();
if ("" == "") {
  $UpdateQuery = new WA_MySQLi_Query($local_i);
  $UpdateQuery->Action = "update";
  $UpdateQuery->Table = "access_userlogin";
  $UpdateQuery->bindColumn("sg_leader", "i", "1", "WA_DEFAULT");
  $UpdateQuery->addFilter("userlogin_id", "IN", "il", "".(getAllColumns($updated_leaders, "leader"))  ."");
  $UpdateQuery->execute();
  $UpdateGoTo = "";
  if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
  $UpdateQuery->redirect($UpdateGoTo);
I'm pretty certain the problem is with
How can I make this work?
Try updating the queryobj.php file... I've attached a newer beta version.
Jason
This post has been deleted.
Jason
I'm getting an error on any query using the beta file for lines 340-348
Notice: Undefined variable: query in C:\xampp\htdocs\ALF\webassist\mysqli\queryobj.php on line 340
Notice: Trying to get property of non-object in C:\xampp\htdocs\ALF\webassist\mysqli\queryobj.php on line 340
Looks like the problem is coming from lines 315 or 316
315        if (sizeof($this->RepeatedParams) > 0) $this->resetRepeated();
316        if (sizeof($this->ParamTypes)) {
The variable $query is defined inside of the "if" statement on 316, but it never matches the if statement. That's as far as I was able to follow the logic with the time I had.
Can I get FTP access and a URL and steps to reproduce the problem? I'll need to debug it further.
Jason
Disregard. The beta page works. The problem was this code at the top of my page.
$BIG_SELECTS
$BIG_SELECTS->Statement "SET SESSION SQL_BIG_SELECTS = 1";
$BIG_SELECTS->execute();
Not an issue on this page, but I do have some pages where I need to keep that code and would like to use the queryobj.php page. Any suggestions on modifying the BIG_SELECTS query to work with the beta page, or vice versa?
It might be a permissions issue not allowing the session set from the page for the connection. You could debug by writing information about the error causing the query to fail once this code is added back.
Jason
Hey Ray, is there a version of this file available now that will work for all my pages? Currently I can only use it in certain places where I need to do the WHERE IN il, because throws a bunch of errors on other pages. I have the original file and use it in most places and call this beta file in a few unique places, but I'd like to be able to just use one file so I don't have to separate my queries into different pages (calling both files on the same page seems to cause errors as well).
There is an updated version that is part of Data Bridge. I think it includes this fix and should be able to be used on all of your pages.
Jason
It says I have Data Bridge Version: 1.2.3 installed. That's the current version right? But, my queryobj.php file is version 1.5 (which is much older than the beta file). I'll attach my current queryobj.php file so you can take a look at it.
