Escaping Quotes in a URL
Thread begun 9/03/2009 7:02 pm by Travis250923 | Last modified 9/08/2009 7:47 am by Travis250923 | 4517 views | 5 replies |
Travis250923
So there has got to be a better way to get this to work. Here is what is working:
$url = $row_rsComments[url];
if(empty($url)){
echo $row_rsComments['name'];
else {
echo "<a href=\"";
echo $row_rsComments['url'];
echo "\">";
echo "</a>"; }
However if I attempt to put the url into one echo statement it doesn't seem to work:
if(empty($url)){
else {
echo "<a href=\"$row_rsComments['url']\">$row_rsComments['name']</a>";
anonymous
Travis,
Your best bet is to clean up the code a bit and close and re-open the PHP tag in this method:
$url
if(empty(
$url)){
echo
else {
<a href="<?php echo $row_rsComments['url']; ?>">
<?php echo $row_rsComments['name']; ?></a>
<?php ?>
Notice how after your else bracelet, I close the PHP to revert back to normal HTML allowing me just to sink PHP echos commands where needed without using escaping slashes... then just simply reopen the PHP tag at the end to clear the bracelet from the original command.
Cheers,
Brian
Dave BuchholzBeta Tester
Travis,
you need to concatenate your recordset value like so to string it together
$url
if(empty(
$url)){
echo
else {
echo
'<a href="$row_rsComments['url']">' $row_rsComments['name'] . '</a>';
Note that I use a single quote (') so that I do not have to escape the double quotes in this instance.
Travis250923
Dave,
Using your code gives me this error:
Parse error: syntax error, unexpected T_STRING, expecting ',' or ';' in C:\Apache2\htdocs\ecochic\mommatalk_detail.php on line 376
This echo statement is line 376:
echo '<a href="$row_rsComments['url']">' . $row_rsComments['name'] . '</a>';
Travis,
my apologies, change the echo statement to read
echo '<a href="'.$row_rsComments['url'].'">' . $row_rsComments['name'] . '</a>';
my fault for typing code and then not proof reading it properly !
Travis250923
That did it thanks.
