Undefined index error messages
Thread begun 5/25/2016 10:07 am by gail.bergan407744 | Last modified 6/02/2016 11:45 am by Ray Borduin | 5459 views | 20 replies |
gail.bergan407744
I'm trying to add an email message to a form that was working great...until I tried this. A member updates their own info and uploads it to our database. A couple of people now need to be notified of the changes. I read some of your responses regarding Universal Email and the above error messages - they have to do with the waue file. I tried doing what Jason suggested in a few of the responses - deleting mail_php.php and mailformatting_php.php and then regenerating UE to recreate them. I did upload the new files (in fact, the entire WA folder, because I had to regenerate the whole server behavior). Now the error I'm getting is:
Fatal error: Call to undefined function writeUEProgress() in C:\Data\Websites\GCSSEPM\update_self.php on line 107. I'm attaching the file and hoping for some help.
Your email include files got placed too low on the page. Move lines 166-167 up above line 79 and this error should go away.
gail.bergan407744
Hi Ray,
Moving those lines did get rid of that error. But I'm still having problems with the file. Before trying to add this email function, it was posting changes back to the database just fine. Now, I get no changes posted, plus I'm not getting the test email either. I've attached the file again. I did make sure that the waue_update_self_2.php file had the MailTo filled in and that it was uploaded. Hopefully you can spot what's wrong!
Gail
Does it redirect to the thank you page?
It looks like it should work. You can try debugging by adding these lines below line 73:
var_dump($UpdateQuery);
die();
gail.bergan407744
Yes I get the thankyou page.
The error I get is (after a full page of text, this is at the bottom, no other errors show):
["Error"]=> string(41) "Data too long for column 'yrend' at row 1" ["ErrorNo"]=> int(1406) ["ID"]=> int(1) ["Debug"]=> bool(false) }
You'll recall that we set all these 'date' and 'year' columns to be VARCHAR and in this case it has a length of (4). It has a default value of 0000, because my bulk emailing software required that 'something' be in that field. Well now apparently it's preventing this form (and maybe others) from posting?
UPDATE:
HERE'S THE ENTIRE TEXT IF YOU WANT TO SEE IT:
The code still has yrend as a time field not varchar... update line 65 from:
$UpdateQuery->bindColumn("yrend", "t", "".((isset($_POST["yrend"]))?$_POST["yrend"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("yrend", "s", "".((isset($_POST["yrend"]))?$_POST["yrend"]:"") ."", "WA_DEFAULT");
gail.bergan407744
OK, I did that. Now I'm getting the following error when I Submit. File attached. By the way, all of a sudden DW does NOT like this file. It keeps freezing up & crashing as I try to work with it, even after restarting. Anyway:
UPDATE: I neglected to mention, this time it DID make the change to the server. It just gave me this text dump, I did not get redirected to the ThankYou page, nor did I receive the Email.
Remove the debug code we added:
die();
it should be working now.
gail.bergan407744
OK, no more screenful of text and the changes are posting to the database. But still no email message.
Does it go to the thank you page now? It looks like you have two email messages on the page, is that on purpose? If so, you should only have a redirect in the second one.
