exporting doesnt work for one site but does for another
Thread begun 5/24/2016 2:34 pm by Christopher West | Last modified 5/25/2016 8:37 pm by Ray Borduin | 2961 views | 4 replies |
Hi I am a little lost. I have a PHP function that writes all email address to an .csv file. This works fine for a latest project I am working on.
However when I duplicate the code to a previous website project it doesn't output any email addres. instead it outputs the actual SQL to the .csv file.
This is what is exactly outputted to the .csv file = SELECT NewsLetterEmail FROM newsletter<BR><BR>
Here is the code:
(I have made sure I uploaded the relevant files etc to the old website).
<?php require_once('../Connections/ecartdb.php'); ?>
require_once('../webassist/mysqli/rsobj.php'); ?>
header
('Content-Type: text/csv; charset=utf-8');
header('Content-Disposition: attachment; filename=emails.csv');
$output fopen('php://output''w');
$rows = new WA_MySQLi_RS("rows",$ecartdb,0);
$rows->setQuery("SELECT NewsLetterEmail FROM newsletter");
$rows->execute();
while(!
$rows->atEnd()) {
$row = array($rows->getColumnVal("NewsLetterEmail"));
fputcsv($output$row);
$rows->moveNext();
$rows->moveFirst(); //return RS to first record
Why would it work for one website and not another? (Could it be that it works for my new website as I only have 3 email address in the database...and the old website has a few thousand?
Why would the old website output the SQL query (when the new website doesnt do this).
Well done a few tests, its not the size of the table in the database. and doesnt appear to be the database itself.
I wonder if its because (a) I am running it on a server that isnt using the latest PHP version? or (b) the old website was designed before MySQLi webassist server behaviors? However I had sure I uploaded the mysqli server behaviors folder and made sure it was connecting to a mysqli database connection (the file is a standalone php file so the website should have any impact on it.
Any thoughts would be great :)
Chris
I'm wondering if the table or column name is different on the new server. That may be the first part of an error message saying that query is invalid. Please test it on the new server using phpmyadmin to be sure the SQL statement itself isn't wrong.
Dont worry its been fixed. For some reason (even though I did ammend the connection file) it somehow hadnt saved on the server.
Chris
ok I got it working, but the SQL is throwing out syntax errors on some of my queries. for example:
$rows->setQuery("SELECT * FROM newsletter WHERE NewsLetterOptIn = 1 AND NewsLetterEmail IN (SELECT OrderBuyerEmail FROM `orders` WHERE OrderCouponCode != "")");
This is the error: Parse error: syntax error, unexpected '")"' (T_CONSTANT_ENCAPSED_STRING) in /homepages/41/d416416140/htdocs/admin/exports/export-voucher-customers.php on line 10
You will have to use single quotes in your query since the string is encapsulated in double quotes.
