Paypal sandbox works on localhost but fail on server (1&1)
Thread begun 5/21/2016 5:56 am by fedtek425743 | Last modified 5/23/2016 3:51 pm by Ray Borduin | 2523 views | 2 replies |
fedtek425743
(express checkout)
I get this debug info:
...omitted..
["ECO_Auth_Result"]=> string(0) "" ["WA_HTTPS_Redirect"]=> int(0) ["PS_ActivationError"]=> string(0) "" ["orderAdd"]=> string(0) "" ["WA_BillingAgreements"]=> array(0) { } }
But on my machine works well. I haven't yet a live paypal account for testing, I use the same sandbox credentials that I use locally, and same admin settings.
Any ideas?
Thanks Federico
Is it possible that CURL isn't installed on the live server? It should be by default, but it appears to not be connecting to the paypal service at all because all of the settings are blank.
Did you log into the paypal sandbox first? I seem to remember that is necessary.
Personally I seldom use the paypal sandbox at all since it is so easy to refund transactions on paypal and the fees are all refunded as well. I'd try in live mode and see if you have better luck.
fedtek425743
cURL OK I put this code in a php page
$toCheck = array('curl_init','curl_setopt','curl_exec','curl_error','curl_close');
print "<p>Status of needed built-in PHP functions:<br/>\n";
foreach ($toCheck as $n => $chkName) {
print "function <b>$chkName</b> ";
if(function_exists($chkName)) {
print " is available<br/>\n";
} else {
print " is <b>NOT available</b><br/>\n";
print "</p>\n";
function curl_init is available
function curl_setopt is available
function curl_exec is available
function curl_error is available
function curl_close is available
Also live it's ok just tested!
Idk why sandbox fail on live server, but with my live credential, yeah!
Thank you Ray
Federico
